managed to find one in newcastle $440 dollars now to ring boss and ask for another day off can,t do much and car in bits in goulburn and Iwork in sydney
In the weekend did the head gasket and thought I would check the bolt so ripped the sump off and put a spanner on the bolt to undo it it felt tight but when I started to undo it,it did not feel right then I could here the pump turning had to use a G clamp on the sprocket to force it against the shaft to get bolt out.
The sprocket is worn with a round hole where it should have a flat to drive against pump shaft the shaft on the pump rotor is stuffed as well I am stuck out in goulburn tring to chase up parts so far the cheapest is $900 problem is you have to buy the whole pump and the pump housing is part of the stiffener plate.
Will post pictures when I get back to sydney If any one no where there is a stuffed motor I can rob for parts otherwise will hire a car and drive to Sydney tuesday morning my phone number is 0412160376 I am in the goulburn libary at the moment looking for wreckers
disco seriesII mods so far:-bullbar,hyd winch,
detriot locker,lsd front,C.D.L kit,chipped and bigger intercooler,2" lift,rock sliders, lsd in transfer case, modified auto trans.
In the event of nuclear war,Disregard this message
Sorry to hear that. Guess you tried the Canberra suppliers.
if you stay there i can give you a lift back to sydney on sunday.......
i will be out that way on saturday....going to braidwood.......
[IMG]http://msnusers.com/_secure/ovqaaaccaswm!xkxfpt3pfocsf2ei*1bgnvxpezep2fonugyb5 w43v[/IMG]here is some pictures of the stuffed parts
the stuffed oil pump rotor
and the sprocket
still trying to get the hang of posting pictures these need to be a bit bigger to see the damage
