You can use the feed for the Caravan plug - switched.
Or perhaps the Aux socket in the rear (it will wake when car is unlocked).
What are you doing for a supply feed?
Even with a DcDc unit you need fat cable![]()
I'm about to install a lithium battery in the rear of my D4 and the DC-DC charger requires an ignition lead to be connected. Does anyone know if there is such a wire near the rear of the car I could pick up from? Preferably the driver's side.
Rod
D4 MY16 5 seat TDV6 - LLAMS, Custom Drawers, OL Bar, Toyo Open Country, GOE Rims, Lithium DBS, eDiff, OA Long Range Tank, GAP Tool, Tracklander rack, Mitch Hitch, TPMS & Safari Snorkel
Hi Rod, all new European vehicles, including Land Rovers, have an accessories/fridge circuit in the S12 plug ( white Plug ).
This circuit is only live while the motor is running and is ideal for controlling a DC/DC ignition feed.
Hi Rod and what are you trying to achieve?
Depending on the type ( brand ) of lithium battery, you will need to fit at least a 100Ah to a 120Ah lithium to equal the capacity you have now, and the only advantage would be a weight saving of about 5Kg.
But you will loose a fair bit of cabin/cargo area.
Even if you fit something like a Sterling 60 amp DC/DC charger, you will still need to drive for a long time to replace what your existing system can replace.
As many of the lithium batteries will not tolerate 60 amp charging, and if you fit anything smaller than the 60amp DC/DC charger you will need to drive many hours more to recharge the lithium compared to what existing system can do.
No other system looks after your cranking battery like your existing system does.
So again, what is the reason for going to a lithium battery?
Tim, I'm adding a 100amp slim lithium to the rear underfloor storage area of my 5 seater so it doesn't take up any space at all. I'm going to add photos and write up about this but won't start the job for another 2 weeks or so. The reason I'm adding this battery is, for the past 3 years of the Traxide system I've only ever got about overnight use before the low voltage cut out happens and the fridge goes off. With the lithium I'm hoping to get 2-3 days before charging. I know the Traxide system is good the for the starter battery but also, as a principle of mine, I would really like to leave the starter battery to it's original purpose and not for accessories duty as well.
I am all about weight saving and this is the reason I may take out the Traxide DBS but I'm still tossing that up as it's not much of a saving. I have two camping setups, one with a camper trailer with AGM battery and one without trailer. The Traxide could still supply the trailer, plus a fuse box I have under bonnet, but I've been told by the tech at Projecta that the specific lithium charger I have will also charge AGM batteries on my trailer so it may have a dual role depending on the setup is use.
Anyway it's a work in progress project. Thanks for all your input.
Rod
Hi Rod, you should have raised the problem sooner as this is not right.
Most people get at least 2 days use and for yours to go flat so quick, there is a problem.
If the problem is something like driving times, then you will have an even bigger problem when trying to recharge the lithium battery as it is a much slower process and requires much longer drive times.
Can you post up your normal driving habits?
Shouldn’t that read “New projects are an opportunity for unconstrained thinking”
When planning a new project, not being constrained by concepts of new or old needs to be factored. As well as initial trouble shooting and review of current systems and why they may be underperforming.
