Head Light Washers
					Does any one know if there is a way to program out the head light washers. These are probably the most useless feature available on any car really as 99.99% of the time you never need them.
However, I really hate how just after you wash your car and hit the washers  to get a quick clean for the windshield and the headlight washers come into play and put fluid everywhere not just on the headlights, waste precious washer fluid for something not dirty . Out in the bush its even worse as it collects dust in a major fashion making it pick up more dust after getting wet.  Like many of us I have been out bush after it has rained  and you may need it then but even then you tend not to travel in boggy conditions at night.
If not,  will just put some small sprinkler micro taps in Line  so I can use then when I need them.
I am sure many of you will have the same gripe even though it is only a small one .   A headlight washing switch from factory would be a good idea so you only use it when required. There's an idea for Landrover
				D5 2018 SE TFT display  18" Tuffants  Cooper ATR LT ECB Bullbar  Drawers
