Thread: D4 master window switch panel how to remove
    Dec 2011
    Wollongong
    Has anyone removed the master window switch panel on the driver side door?
    My rear view side mirrors are no longer responding to the “coolie hat” controller so was hoping to remove it and have a look internally. Failing that I’ll put a new panel in.
    Tried to find some pics online of a removed one to reverse engineer but can’t find enough detail to work out how to remove it from door.
    Mike
    Apr 2012
    Whyalla, SA
    Door trim panel off, then access from underneath, 4 screws and it’s off.
    Dec 2011
    Wollongong
    Thanks, I was under the impression that I might be able to do it without door trim removal.
    Mike
    Apr 2012
    Whyalla, SA
    No such luck unfortunately...
    I have my replacement unit sitting here waiting- my window lock button doesn’t function.
    Had the spare here for about 4 years D4 master window switch panel how to remove
    BradC is online now Super Moderator
    No one of consequence
    Supporter
    Mar 2018
    Perth (near Malaga)
    Can't rush these things.
