Results 1 to 9 of 9
Thread: Harmon Kardon Radio Code???
    Ron Hall Guest
    Hi Guys, I have a 2007 Discovery 3, 2.7 litre HSE, I do not have the radio code for the standard Harmon Kardon system. According tothe UK, the radio installed is a 'Self Coder' meaning it is coded by theowner from new, therefore, no record of this code exists on our system.
    1. Is this correct ?
    2. Is there a default code?
    Thanks in advance Ron
    Jun 2013
    Universe A
    I thought the canbus systems didn't need a code?
    Could be wrong though, I know the lower spec ones don't.
    James
    St Helena,Melbourne
    1.13 MB
    Quote Originally Posted by shack View Post
    James
    Same here, my basic CD400 didn't require one.
    2004 Jayco Freedom tin tent
    1998 Triumph Daytona T595
    1974 VW Kombi bus
    1958 Holden FC special sedan
    Narangga's Avatar
    Jun 2008
    McMinns Lagoon NT
    Why do you need a code?
    I have a 2006 HSE and I have never needed a code. When the battery is disconnected my system even stores the programmed memory stations which are accessible again once the battery is reconnected.
    Cheers, Dale
    'The D3' - 2006 TDV6 HSE
    Previously Enjoyed:
    2000 D2 Td5 - plus!
    Ron Hall Guest
    Guys, I wasn't game to disconnect the battery in case there was a code, strange the UK didn't say that we don't need one.....thanks a million anyway.
    Narangga's Avatar
    Jun 2008
    McMinns Lagoon NT
    Quote Originally Posted by Ron Hall View Post
    Having had a D2 that required it I understand where you're coming from.
    Cheers, Dale
    Previously Enjoyed:
    2000 D2 Td5 - plus!
    Ron Hall Guest
    Sort of solved
    So if you remove the battery cover and look beside the Fuse box in the engine bay, there is a series of tips and hints in pictorial form, one of them indicates that you can disconnect the battery for a maximum of 120 seconds without any issues so I did it for about 180 seconds and all it did was loose the clock and stations, I did do it today but I am tipping if you do the disconnect for less than 120 seconds everything will be retained. Thanks for all the help and advice. Looks like the radio does not need a security code in the D3 but the station and clock settings are volatile type memory i.e. they need power to retain data.
    Bangor, NSW
    Battery disconnection
    Ron - you'll probably find the one-touch front windows will also need to be reset.
    Rob
    Narangga's Avatar
    Jun 2008
    McMinns Lagoon NT
    Quote Originally Posted by jonesy63 View Post
    Rob
    The only thing that needs resetting on mine is the clock, albeit that with the 2006 version I only have the driver's window control as a one touch. Radio memories remain and so are not volatile.
    Cheers, Dale
    Previously Enjoyed:
    2000 D2 Td5 - plus!
