That code is for the secondary turbo's inlet isolation valve, sometimes called the air shut-off valve, which is located behind the bottom right of the radiators and accessed by removing the clip-on panel behind the front of the right wheel.  The valve's vacuum tube runs up the front of the motor to where the solenoid is located at the top.  You can reach in to move the valve's linkage by hand but may have to remove the valve by undoing the hose clamps and removing the 3 bolts, watching out for oil draining from the bottom of the I/C.
The early version of the valve was prone to having its linkage jammed externally by dirt whereas the revised version has a much more open pivot point that isn't nearly so prone to jamming.
				MY21.5 L405 D350 Vogue SE with 19s.  Produce LLAMS for LR/RR, Jeep GC/Dodge Ram
