Thread: Reason to pop open wheel inner guards
    South Yundreup,WA.
    Well, fitting a snorkel (what an abortion of a design, but thats another story). Popped the inner guard and removed the mudflap and found it full of leaves that obviously come down from the windscreen area. Potentially a very likely rust spot. Poor design. Now to do the other side.
    2011 Discovery 4 TDV6
    2009 DRZ400E Suzuki
    2003 WK Holden Statesman
    Departed
    98 Ducati 900SS Gone & Missed
    Facta Non Verba
    Oct 2012
    Yes it’s a gum tree leaf trap because the inlet above is so huge on both sides. The leaves go from the windscreen into the drains. You could maybe add some mesh as a blocker. Even some very porous foam cut to size??
    You can also just release some screws underneath and pull apart the bottom end of the guard enough to get fingers in and get the leaf matter out. Because it drains so well it stays dry enough to not cause a soggy rust inducing mess.
    A fire risk more likely!
    Mar 2016
    Quote Originally Posted by PerthDisco View Post
    It’s a Disco. It’s par for the course.
    2007 Audi RS4 (B7)
    Adelaide - Torrens Park
    Quote Originally Posted by CraigE View Post
    I would be very surprised if you had rust, especially in Australia.
    South Yundreup,WA.
    Yeah maybe, was msotly dry but some thick dirt in there also that could trap moisture, will be looking at some mesh of some type.
    2009 DRZ400E Suzuki
    Departed
    Facta Non Verba
    Sep 2014
    Baldivis WA
    Known issue, on mine it rusted out the support brackets for the mudflaps. These arent really required, fitted a new set without them and you can't tell.
    Body etc is fine.
    Jan 2014
    Perth Western Australia
    *Yes everytime I do a body off, that spot is full of at a minimum dry leaves, but also mud dirt etc.
    *Rust is almost a thing of the past with alloy steels and dipping by manufacturers.
    BUT I would still reckon in horrible places (wet, salt on roads etc) such as the U.K there might be a few that have rust in that spot.
    Daz
    Oct 2012
    Quote Originally Posted by DazzaTD5 View Post
    The UK videos are phenomenal. The car itself looks perfect but when they go underneath to do anything there is rarely a bolt that comes apart without shearing the head off or needing the gas axe or grinder. Brake and AC lines are corroding out within 10 years.
    I remember as a kid my old man getting steel welded into the sub frame and floor section of his not that old back then morry minor 1000!!
    The MOT system seemed to allow such patching privided it was done by an approved repairer. It's a miracle that any older cars survived..and some eg Lancias did not.
    I had an ex UK Jag XJ6 which continued to rust itself to death despite coming to Aus at a very young age. It was everywhere underneath...guards. sills..sub frames..suspension..brakes etc😐
    Mar 2016
    I saw an article on D3UK where the D3 had rusted in the body under the covers where the bottom seatbelt mounting was. Car was declared a write off.
    2007 Audi RS4 (B7)
