Results 1 to 10 of 17
Thread: D2 axle breather coupling
    NSW far north coast
    A Q regarding the push connectors on the axle tubes.
    Are they a generic airline coupling like an SMC or do I need to go genuine?
    I had a **** load of water in the rear diff and suspect the coupling isn't watertight.
    I'll probably run a new breather line, too.
    Had some in the front, so will swap it out too.
    Apr 2012
    Whyalla, SA
    I believe they are a std style.
    Apr 2011
    Dungowan
    Quote Originally Posted by rick130 View Post
    Not sure if the same but, had a blocked breather on the front of my D1, replaced the 1/4” nylon and banjo fitting with a 1/8” BSPT push in elbow to 6mm nylon hose. That’s what I had lying around at the time.
    '93 D1 V8 auto
    '93 D1 200Tdi 2-door, ARB's, MD transfer, sill tanks, winch, 2"lift.......
    '95 D1 V8 auto......gone
    '86 V8 RRC.....gone
    Narre Warren South
    They are a fairly standard airline fitting.
    The standard ones on my Defender were zinc plated steel and rusted internally & blocked.
    As I work in the pneumatics industry I fitted nickel plated brass 1/8" BSP to 6mm swivel elbows, problem solved.
    Colin
    '65 Series IIa Dormobile
    '70 SIIa GS
    '76 SIII 88" (Isuzu C240)
    '81 SIII FFR
    '95 Defender Tanami
    Motorcycles :-
    NSW far north coast
    Deefers (and I suspect the D1 & RRC) are banjo fittings but the D2 uses a plastic push fitting into the axle tube.
    I'll go for a crawl and see if I can remove it
    Narre Warren South
    When I advertised fittings & tubing on the forum years back someone came round with a Defender that had some odd fittings in the axle. From memory 4mm OD tube rather than 6mm. It was raining at the time so I didn't investigate any further.
    The original on my '95 Defender was a banjo fitting which I tend not to use in pneumatic applications because they restrict the flow too much, hence fitting a swivel elbow.
    You can buy the push fit collet mechanisms to press fit into your own product, these require some form tooling to machine the port to house them. I wonder if LR went in that direction and pressed the collet mechanism directly into the axle.....
    Colin
    '70 SIIa GS
    '81 SIII FFR
    '95 Defender Tanami
    Motorcycles :-
    Apr 2012
    Whyalla, SA
    At worst (did this on my D1)...
    Remove original, drill / tap housing, fit elbow with press fitting.
    On the D1 I ran 2 T pieces also, and drilled and tapped each swivel housing and fitted breathers in them as well.
    NSW far north coast
    Yep, I could end up doing that yet.
    NSW far north coast
    Quote Originally Posted by gromit View Post
    Colin
    I'd say so as the collet is directly into the axle tube
    NSW far north coast
    I don't think the tube was pushed home properly past the O ring, and the fitting was full of crap.
    Cleaned as best I could, recut the tube with cable cutters and pushed home again.
    I'll test it somehow on the weekend.
    It's 6mm tube btw.
