If it contacts anything in the coupling it will wear it. I'd be taking that one back for a change over, it is damaged. They've just tried to get away with it. If its not a problem, then I'm sure they can put it on the shelf for resale.
I recently paid to have, amongst other things, a hayman reese towbar fitted to my 90. Everything looked fine in the afternoon light so I drove home. Fast forward to today, I decide to remove the receiver hitch just incase someone takes a liking to it and pinches it. Upon removal and closer inspection I noticed the mechanic used vice grips to hold the ball in place while tightening it up. This has left deep gouges in the ball on both sides:
To say I'm disappointed is an understatement as you spend good money on professional labour to see a rookie move like this. My question to the brains trust is, can gouges like these damage the cup on the trailer or cause any issues while towing?
Slunnie
Take it back.....one would wonder why they didn’t just use the big flats at the bottom.
back she goes.
that doesnt even get to being unfit for purpose, it stops right at goods damaged by poor workmanship.
but, yes if that gets in contact with the reciever it will shred it in short order.
if you want to go unfit for purpose.
1. its damaged and will damaged the item its designed to couple to.
2. if its been damaged by holding it with the appropriate tooling during installation then the metal has not been correctly hardened
Just because I'm evil and nasty to shoddy spanner swingers I'd be going so far as to inspect every nut bolt washer, fitting, electrical connection, panel and structural member for any signs of stress, deformation, percussive installation, protective finish abrasions, cracking and undue removal. I'd find it and then be providing the old "rectify or remove at your cost and refund the purchase price" routine
I wouldn't cop that either,incorrectly fitted.Rough job.
It wouldn't have taken long to find a 15" shifter to fit the flat that is there to do the job properly, one would think.
Or the correctly sized spanner.
Particularly if these guys do that type of work all day.
Actually, looks like the marks are from stilsens.
This is actually one of 4 issues I found with the work done to my car, and I will see how the company responds to this before I name names.
Supplementary question, is there any way that the installation of a diff locker could cause an increase in fuel consumption i.e. increased drag?
Slunnie
Harrop e-locker. Car seems to corner fine and no strange noises or steering feedback, maybe its just my paranoia, but the needle just seemed to drop real fast on the return trip and I was wondering whether incorrect preloads or even just the fact that its a new 'tight' centre might be causing drag.
Again it may be nothing, but I swear whenever I get someone else to touch my car there is always some bull**** like that that happens....
stillsons more likely...
actually-- those marks are wrong for both,, hmmm
bench vice?
and if the "highs' are removed,, it will work fine..
90% or wear is front and back,, normally no marks on the sides..
