I may be lucky but haven’t had a problem touch wood. The air suspension is not a no maintenance system. I replace things before they fail and even before they they appeared on the way out. I’ve changed the compressor, the valve blocks and air springs. Checked the airlines and connections. Same with the alternator and upper water housing. They are all fully functional spares. If you are going remote it is just false economy trying to get your “money’s worth”. It doesn’t really cost you much more by bringing the spend forward by say six months.
				MY08 TDV6 D3 Zermatt Silver, B.A.S ECU Remap, ARB Bar, 12K Kingone Winch, 2x100Ah LiFePo4 Auxiliary Power, Safari Snorkel, Baja Rack Roof Rack, Brown Davis Aux. Tank, RWC, Front Runner Rear Ladder, Drifta Drawers, Doran TPMS, LLAMS, GAP IID BT.
