Results 1 to 10 of 18
Thread: Help with a dead Defender
    Dec 2017
    New South Wales
    Anchor Help with a dead Defender
    Just got back into a TD5 defender after a dry spell bought a project car described as needing a new engine MY2000 with 173k...
    head was dud so decided to do a complete engine swap with a known good engine from a rusty D2 auto...
    So...
    swap went fine with The engine slotting in nicely but now can’t get it started...
    I know the engine is good as I had it running just before taking it out so am ruling out anything on the engine...
    I have not recoded injectors as I don’t have access to a scan tool which works (yet?🙄&#128580 but I’m told this won’t stop it starting so I’m carrying on regardless
    things I have tried to date
    retraced the fuel lines
    changed fuel filter and bleed valve
    changed MAF and the crank sensor with known good units (from the running D2) wrapped crank wiring in alifoil for better shielding
    Cleaned the ECU connectors (no oil showing up anyway..) it’s got power as dash lights all up
    charged battery and tested 13v no issues and is turning it over fine..
    checked and tested the fuel cut switch on bulkhead...
    run the bleed cycle around 20 times.. only sound other than the pump is a peeing from inside the cooler which I’ve heard on others and doesn’t appear abnormal...
    charged battery again.....
    checked fuel pressure at regulator 5 bar...
    checked and run an earth from engine to bulkhead..
    there are 2 thinks I am suspect about...
    the bonnet close switch broke the terminal off and this is now earthed (as I think it works when the bonnet presses it down...)
    the only other thing I can see is the radio code is requested from the OEM radio (tapedeck) when pos 1 on key is set.. a couple of presses and I can get this to play music (despite not having code) but when cranking the engine the radio “red light” on the top left corner is flashing - is this immobiliser?? I thought this was on the dash cluster and nothing shows there... I don’t have any fobs just the bare key recieved from previous owner who never suggested a fob was needed and it’s not central locking so unsure on how the immobiliser function can be checked or disarmed if this is the case... TD5’s are hard programmed into the ECU I think... fuel pump is running and cranking sees diesel smoke out the auspuffer so looks like injectors are firing...
    any suggestions???
    I’m getting flack from the little lady after spending Easter trying unsuccessfully to romance the def..so have to hear it running sooner rather than later.. I must be missing something simple but it’s kickin my xa$#! She’s suggesting I should use it as a boat anchors so honour must be preserved!!!
    Jun 2015
    A few years ago, I replaced the failed MSB ecu in my 1999 130 with a chipped one from TRS, and it would not fire until the injector codes were changed.
    Dec 2008
    Hi,
    The injector coding should not stop it firing and running.
    On the other hand, if it is immobilised, you could crank it from now to Christmas with no joy...
    I have found a good scan tool (I use nanocom) to be essential with D2 TD5..... And it will tell you if it is immobilised.
    Gumnut
    Jan 2014
    Perth Western Australia
    I'd suggest before you start touching every possible item that may or may not prevent the truck from starting...
    *So you have done the depress throttle 5 times with ignition on, left it to do its thing.
    *Then with a charged battery, hold throttle to floor, crank, crank crank for what seems a lifetime, then as it starts to splutter, bring throttle about half way up, while still cranking, until it comes to life. There will be lots of white smoke.
    other things to note.
    *The replacement engine was known to be running by you?
    *Was it all starting before you removed old engine?
    *Non coded injectors wont stop it from starting or running, it's idle may not be perfect is all.
    *Bonnet switch wont stop it from starting
    Daz
    Jan 2014
    Quote Originally Posted by Standard View Post
    No, what prevented it from starting likely was the engine computer hadnt been sync'd with the bcm.
    Daz
    Jan 2014
    Quote Originally Posted by Footnote10 View Post
    No they arent, the Nanocom can disable the immobiliser (said in a general end point).
    It actually sounds like its already trying to start
    Daz
    Dec 2017
    New South Wales
    Defender help
    So in answer
    Yes the donor D2 ran and heard it myself before taking out the engine...
    The bleed (5times throttle) has been done multiple times and I’ve cranked till battery tires (3 sets of 20 seconds - stinky white smoke out the back so I assume diesel making it through injectors...
    still using the original defender ECU so didn’t expect any reprogram other than injectors (have bought an early Hawkeye but cable is u/s so can’t read.. all my other scan tools not reading...)
    Dec 2017
    New South Wales
    Defender help
    The white smoke has made an appearance for a number of tries but doesn’t seem to catch for more than a second then dies off.. will do the depressed 5 and crank a few more times tonight and report back thanks in advance for all suggestions
    check the plumbing for the fuel hoses, if you got them backwards or ass about on the filter/tank you'll get this issue.
    to really prime it up find the fuel pump relay and bridge it out, keep the battery on a charger and let it sit for about 5 minutes. leave it bridged and then do the hold it pinned and crank it (I advise cranking it without the throttle pinned until it gets oil pressure then going again)
    some also checks are the glow plug circuit and relay
    the prang stop button is reset properly
    Dec 2017
    New South Wales
    Def help
    like the bypass idea will give it a shot...
    lve run through the pipes and all agrees with LR service manual it’s also been press. tested at the regulator with 5+ bar after a couple of efforts it’s chucking enough diesel out the back to start the neighbours yard..
    glow plug circuit is working checked👍
    prang stop button also checked.. and bypassed just for the sake of it...
    im seriously suspecting the immobiliser has kicked in.. got a call in with LR for an EKA code as I didn’t get a plip fob as never needed before according to last owner... I’m hoping it’s that...
    anyone got a nanocom they are looking to get rid of?...I can see one in my future🤨 I’ve got a spare TD5 engine to trade🤣
