Results 1 to 10 of 13
Thread: Does anyone do rubber Defender-like mud flaps for a D4? <EOM>
    Feb 2017
    Keen as.
    Dec 2009
    Baldivis WA
    I fitted Defender 90 rear mud flaps to the rear of my D4. I used genuine LR as they had the “Land Rover” logo. You need to remove the metal bracket and trim the rubber so it fits around the exhaust.
    2014, MY14 Discovery TDV6, Fuji White (2018-Now)
    2003, Discovery 2a, Td5 Manual, Zambezi Silver (2012-2018)
    2007, Adventure Offroad Campers, Grand Tourer (2015-Now)
    Dec 2009
    Baldivis WA
    Discovery 1 fronts fit the front of a Discovery 4 without cutting, just need a couple of new holes for fixing screws. I wasn’t fussed about the ‘Mountain’ logo so didn’t use genuine parts.
    Feb 2017
    Quote Originally Posted by kelvo View Post
    Kelvo do you reckon the D1 fronts would also fit on the rear?
    Feb 2013
    Wamuran, Qld
    2 pairs of eBay Defender / County mud flaps @ $35/pair, and some Land Rover decals also from eBay
    Ron
    2013 D4 SDV6 SE
    Dec 2009
    Baldivis WA
    Quote Originally Posted by BrianElloy View Post
    They would fit, but would be too small IMHO. The D1 fronts are only 240mm wide, the Defender 90 rears are 360mm wide.
    Bunbury, WA
    Plenty of discussion here a few years ago.
    D4 Mudflaps
    You will find my fitting 3-4 pages in. Mine are still going strong.
    Kallangur, Brisbane
    Quote Originally Posted by cjc_td5 View Post
    D4 Mudflaps
    I went with the advice from the thread & fitted D1 & Defender flaps, front & rear respectively. 4 years now & still going strong.
    + 2016 D4 TDV6
    Ocean Reef WA
    I did the same and they’re just right. Rears have the logo on and the fronts are smaller but adequate for the job. Got them from Rimmer in the UK from memory. Not expensive and good delivery time.
    I also have chains to hold them up if we go through sand but just leave them attached ‘cos I’m too lazy to disconnect them. 😀
    AlanH.
    Apr 2012
    Whyalla, SA
    On some of the tracks here - going backwards would result in those being torn off by the tyre.
