Results 1 to 6 of 6
Thread: Back pressure?? we dont need no stinkin back pressure..
    May 2003
    On The Road
    Get your thinking caps on!!
    99.87 MB
    I thought I was the only one on the planet that thought needing exhaust back pressure was a load of bull****.
    Except on 2-strokes, but thats a far more complex scenario.
    Slunnie
    and on some NA configurations where you're using the back pressure to do some freaky stuff with pressure pulses and exhaust velocities at the ports in the manifold to increase scavenging at a given RPM band... kind of like 2 strokes but ass about.
    99.87 MB
    Thats it, the pulses are not the same as back pressure, its all about extraction, where 2S are about reflected pulses refilling the CC with charge that blows through.
    Slunnie
    however you do need some back pressure for the pulses to work. to make the pulses work in the manifold you need (and this is the really simple version) some back pressure which changes with the flow velocity. if you have no back pressure you dont get to set up the flow which makes the pulses work.If you're going for a total 0 back pressure configuration you might as well just run pipes as fat as you can as short as straight as you can from the ports
    99.87 MB
    They do, if they can.
    Here is a better explanation of whats happening.
    Slunnie
