Results 1 to 10 of 11
Thread: LLAMS Question
    Feb 2010
    LLAMS Question
    Hi All
    just finished installing my LLAMS Unit (despite the crap instructions) and it works great - quick question though?
    When the vehicle is set to extended mode (LR factory switch) and the LLAMS is set to High (+50mm) that is the highest the vehicle will go using combined vehicle and LLAMS settings.
    Apparently this is close to the OEM hyper extended mode the vehicle would go to when it senses your really stuck.
    Question - what happens if I am at hyper extended (LR Vehicle switch + LLAMS) and then get stuck - the vehicle will then automatically try go what it thinks it Hyper extended but that’s infact hyper hyper extended. Wouldn’t this be too extended and cause damage?
    My head hurts - hope I explained it clearly enough 😁
    Jul 2015
    Sydney, Australia
    LLAMS Question
    2009 Range Rover Sport 3.6L TDV8
    2017 Jaguar XE R-Sport
    Supercharged
    Jags XKR & XJR 4.2L S/C
    Old Jaguar Australia - www.facebook.com/oldjaguarau
    Upgrades and retrofits for late model Land Rover and Jaguar vehicles. www.oldjaguar.com
    NSW SW Slopes
    When the suspension ecu detects that height doesn't increase when it considers there is more height available it will fault. In this situation select a lower combination, normally by switching Llams off so that the height sensor values are no longer modified or at least select Llams medium for less height, then cycle the ignition to overcome the fault condition.
    My suggestion when travelling slowly over very rough terrain is to use native off-road height then add Llams medium for extra height and only use Llams high when absolutely necessary.
    Feb 2010
    Cambo@oldjaguar - I want a compressor that will make mine move like that ! 😁😁
    Jan 2018
    Lilydale, Victoria
    [QUOTE=HarryO;3013782]Hi All
    i see two main reasons for having LLAMS intervene in the factory settings.
    One is to lower the car to the high-speed height for normal travel (there’s lots of info on here about the merits of doing that). The other is to hold the car in off-road height when on rougher gravel roads and where your speed may exceed 40kph. The car will otherwise lower automatically if you exceed 40kph and on many outback roads this can be a problem. The lowering from off-road height is built in to the vehicle design to maintain stability and minimise risk of rollovers at higher speeds.
    The super extended height is really only useful, and safe, in really slow, rough going. There is a big risk of damaging cv joints and other driveline damage, especially on full lock or full suspension droop, so use with care.
    Then there is super extended height which you can “force” the car into if you are hung up on something.
    LLAMS is also handy to quickly drop the car to access height when you need it.
    So I would only use LLAMS when you really need it and unless you are doing really technical off-road stuff, that’s not very often.
    David
    2016 Discovery 4 SDV6 HSE, Mitch hitch, Traxide dual battery, LLAMS, iCheck TPMS, APT side steps and compressor cover.
    2016 AOR Matrix Pop Top camper trailer, now sold.
    2023 Sunseeker Desert Storm (aka Titanium Hardcore ATX)
    Feb 2010
    The Ranges of the LLAMS unit overlap a bit depending on the LR Height selection.
    I think in pictures so this is how I got my head around it.
    Nov 2015
    Black Rock
    Quote Originally Posted by HarryO View Post
    Well thunked! Do you have the original graphic?
    2013 D4 expedition equipped
    1966 Army workshop trailer
    Jul 2015
    Sydney, Australia
    Just FYI, the D3 in the gif I posted, that was two photos in a loop, Access Height + LLAMS-Low, and Off-Road Height + LLAMS-High
    Supercharged
    Oct 2011
    Fremantle WA
    Well done.
    So, I assume from this that the highest LLAMS is the same extension as the normal LR "Extended plus emergency extra to get liftoff" ie the highest possible is the same for both systems?
    Feb 2010
    Quote Originally Posted by DieselLSE View Post
    In pdf
    Attached Files Attached Files
