It is possible that your problem may be due to the method you have used to join the wires. My understanding is that these lines, should not be soldered, but joined by crimping.
it ran fine for the first few months but now it has rough idle when cold gets better when hot. found o2 sensor wires worn through re joined them and still having issues bank 1 sensor 1 not getting hot can some one help
 Master
						Subscriber
						Master
						SubscriberIt is possible that your problem may be due to the method you have used to join the wires. My understanding is that these lines, should not be soldered, but joined by crimping.
Correct, a quality crimp is the best method.
 Swaggie
						Swaggie
						But only for longevity, nothing to do with electrical conductivity. The end of a soldered join becomes a break point if the wire leading to it can move due to the inflexibility of the soldered section.
Like Graeme says soldered joints in high stress environments will fail structurally.
 Master
						Subscriber
						Master
						SubscriberLast edited by Collins; 14th July 2020 at 07:38 PM. Reason: correct spelling error & punctuation
What engine has the OP got?
