Results 1 to 10 of 12
Thread: AEB 2017 Discovery
    Dec 2013
    Pullenvale, Queensland
    AEB 2017 Discovery
    The build sheet for my 2017 Discovery HSE (bought secondhand) states that it is fitted with AEB described as follows "AEB-Lev2CTY and URB+PED".
    The driver assistance screen shows that AEB is switched on.
    I have never noticed it working as in the brakes coming on. The only thing I get is a warning alert when I get too close to the car in front in slow traffic but the brakes do not apply. I think this is the parking alert system working.
    I asked the dealer when I had it in there could they test the AEB. His answer was that if it was not working a light would be on!!! Not necessarily so I would have thought.
    Can anyone tell me what the description above means in terms of the AEB system and do owners regularly experience the AEB coming on?
    Paul
    Blakey
    1958 Series 2 SWB Ex Army Canvas Top (Long Gone)
    1985 Range Rover 4 door Factory Auto (Gone but not Forgotten)
    2006 Discovery 3 HSE (A wonderful thing)
    2017 Discovery 5 HSE
    Dec 2017
    wandin nth vic
    One way to find out if its operational, but could be embarrassing. AEB 2017 Discovery
    Oct 2011
    Hunter Valley
    There are 2 levels at which AEB works. One option is to still allow you to have a head on accident but slows you down before you do, the other is where it would do it’s best to avoid you having a head on accident.
    Seems you have the latter. The system beeps to alert you of a potential danger coming up first giving you a chance to react. If you don’t the. It will brake on your behalf.
    I’ve only felt the system hitting the brakes before I did once in the 2 years I’ve had my D5
    The system beeps frequently in my car on one particular windy road which isn’t very wide, has lots of cars parked along it.
    Ron
    2016 D4 TDV6 Corris Grey
    2018 D5 TD6 SE Silicon Silver - gone
    2011 D4 TDV6 2.7 Indus Silver - gone
    IIDTool BT
    Apr 2012
    Whyalla, SA
    MLR used and inflatable Kangaroo to test it at pre-delivery.
    Dec 2013
    After speaking to the Service Manager he has arranged to have the system checked in a couple of weeks time - I will report back on the results.
    Blakey
    Dec 2013
    Quote Originally Posted by IndusD4 View Post
    Ron
    Landrover are telling me they can find nothing wrong with the system despite the fact that it has never made a sound or applied the brakes. Ron can you tell me how often your system will beep etc at you in normal driving. Would it be like once a day, a week or a month. I just cannot believe that mine does and says nothing ever in 35000 km of driving but apparently is working normally.
    Paul
    Blakey
    Oct 2011
    Hunter Valley
    Mine beeps on average once every 3-4 weeks, but always on the same road. It is likely that the bends in this road with parked cars along it cause the system to alert like a nervous passenger, as at times it looks like you're heading straight for a parked car.
    Maybe do as Tombie mentioned MLR do, get a blow up roo, take it to an empty car park and drive at it at 50km/h. That should trigger AEB. If not, I guess it isn't working.
    Ron
    IIDTool BT
    May 2016
    Trust me, it works. A couple of weeks ago I was on Epping Rd heading home. I thought I was reasonably spaced from the traffic in front in my lane, but it had slowed down (a little). I decided to change lanes...
    In the time it took me to look over my shoulder to check the next lane and look back, my lane had stopped completely and suddenly. Before I could even get my foot on the brake pedal the AEB alarm went off and it hit the brakes in an emergency stop. I could feel feedback through the pedal. I thought for sure I was going to tail-end the guy in front, but it stopped over a car length short.
    That saved me from having my first at-fault prang in over 40 years of driving/riding.
    Pennant Hills, Sydney
    yes it works, mine has worked when a van with no working brake lights came to an abrupt stop, my foot was chasing the brake pedal as slower reaction time. as for alerts etc depends on driving style if you drive normal and allow plenty of space it will never give any warnings, drive more aggressively it will let you know.
    disco seriesII mods so far:-bullbar,hyd winch,
    detriot locker,lsd front,C.D.L kit,chipped and bigger intercooler,2" lift,rock sliders, lsd in transfer case, modified auto trans.
    In the event of nuclear war,Disregard this message
    NSW SW Slopes
    I have it on my L322. It activated at 100 kph while on CC on a slight right bend where a vehicle had partly pulled off to the left. The alarm sounded so I went to veer a little further to the right when AEB activated very aggressively. With a vehicle travelling not too far behind I jumped on the accelerator to over-ride the braking and by the time I looked in the mirror the vehicle behind was quite a long way back, presumably caught by surprise at the unexpected braking.
    The alarm sounds in traffic when I get too close to a vehicle as I start to veer around it. While CC isn't enabled AEB pre-arms the brakes when the alarm sounds in readiness for quick application but I've not triggered braking in traffic.
