Results 1 to 10 of 14
Thread: Portable Sand Blaster
    Mar 2010
    Queensland
    12.97 MB
    Hello All,
    Has anyone bought and used one of these portable sandblasters? It has a 37 litre capacity and runs at 60-125 PSI.
    I would like to sandblast a chassis and firewall; plus some steel 20 inch radius truck rims.
    Would this machine be up to the task?
    Kind regards
    Lionel
    BradC is online now Super Moderator
    No one of consequence
    Supporter
    Mar 2018
    Perth (near Malaga)
    How big is your compressor?
    Do not buy..they are crap..mine is now an oil receiver cause as a blaster it was useless. Sand packs in the base and if you do finally get it flowing it eats the hose...valves and end nozzle.
    Go see a professional for proper blasting.
    These are a waste of money unless you want to convert it to an under hoist oil receiver😞
    I have a Samson sand blasting gun - it consumes more air than my 13cfm compressor can supply. Sand needs to be totally dry so that it doesn't clog. Sand goes in a pot under the gun, just like a spray gun paint pot.
    Narre Warren South
    Quote Originally Posted by Lionelgee View Post
    Hello All,
    As already mentioned, you need a very big compressor otherwise you blast for a few seconds then have to wait while the pressure builds up again.
    Also you have to buy the blasting media, using 'sand' is dangerous (silicosis).
    Sandblasting - my experience
    Wet blasting is possibly an option.
    Wet Sand Blaster
    I have a bigish 3phase compressor and one day will set up for blasting. At the moment, like others, I take my parts to a professional, handy if you can negotiate 'cash' rates.
    Colin
    '65 Series IIa Dormobile
    '70 SIIa GS
    '76 SIII 88" (Isuzu C240)
    '81 SIII FFR
    '95 Defender Tanami
    Motorcycles :-
    Jan 2008
    Nowra NSW
    Hello All,
    Kind regards
    Lionel
    It will not be up to the job even if you have a big compressor.
    the hand piece will be ceramic tipped and will not last long.
    Jul 2008
    You will need a 350 cfm compressor generally for blasting items like chassis wheels.
    You need proper PPE. Blast helmet at a minimum and breathing air.
    The gear to do big items is fair money even renting it ain't cheap.
    Its an intensive process blasting.
    You want a profile on steel for the paint to adhere to, 75 microns would be about right.
    If its a one off take it to a blast shop and get it blasted.
    They will have o/head cranes so the lot can be done in one hit, and abrasive reclamation.
    A proper blast stream and abrade any corrosion out enhancing coating life.
    Unless you live in a desert and its summer, it will flash rust before you can get the paint on it.
    ie trapping rust under the paint, a real no no. Corrosion will reappear before to long.
    Get them to paint it as well. Choose a high build epoxy for best results on the chassis.
    Do that all correctly and it will last for years.
    Don't waste your money on blast gear, buy a bristle blaster, it is your best bet if you are doing it by hand, but it will be (very) slow and the chassis must be in good nick.
    Clive
    Sep 2013
    Darwin
    12.74 MB
    Hello All,
    Has anyone bought and used one of these...
    Kind regards
    Lionel
    I have one - its OK, but not the bees knees. Done a chassis, coach work etc. Slow, but better than a wheel in my opinion, particularly in tight or obscured places. My electric 3 horse power 2 cyl compressor runs almost continually. Need a booth or tent arrangement to be able to recycle the garnet, and protect passers by. Need independent filtered air supply and helmet. Plus peel of visors - number of times with opaque visors I've wondered why the dark spot wont go, to find it is a drill hole. Not something you would use in the modern cramped burbs for the safety of neighbors - the garnet settles quickly but dust may travel - bigger older block better = moving house? The supplied ceramic nozzles oversize very quickly, maybe in an hour or two, and the rubber pipe doesn't last long either; the simple cover over the nozzle to stop grit flow when resting, wears away in a few hours - ditched these for professional hose; and smallest diameter Boron Nitride(?) nozzle ($90 a few years ago), which Blast One said should last me about 300-400 hours with the pressures I use. They will block if you get a water spit past the compressor water filter, they will also block if recycling grit, blockage from very fine waste dust. I wash my garnet to rid of the fines and dust - lay out on concrete in sun dries soon. Also have one of those boxes with gloves - leaks dust like a sieve, requiring P2 or better P3 face mask. Having the gear is good once you get set up. I got a big single door fridge from the dump, waiting to be converted so I can do up to axle housing size items without a tent/booth.
    Dan Gelbart explains the time frame you have to paint your stuff after blasting. Has a whole series of fascinating vids...built his own granite bed lathe, explaining why a fellow might want to machine to a thou of a mm - drool with envy! Woody Alan of metal working...
    Building Prototypes Dan Gelbart part 6 of 18 Coatings - YouTube
    Quote Originally Posted by workingonit View Post
    This is exactly my experience before I junked it to an oil receiver. I use a needle scaler for heavy rust and paint removal (eg on dozers etc) then wire wheel BUT note we are rural so no neighbours to annoy.
    Sep 2013
    Darwin
    12.74 MB
    Quote Originally Posted by INter674 View Post
    Yep, we're rural too - fire up the oil burning furnace with a cloud of smoke and when running clean sounds like a jet engine...
