Results 1 to 9 of 9
Thread: Looking for recommendation on mechanic in Perth
    Jan 2018
    WILLETTON
    Hi all,
    I drive a 2012 disco-4 tdv6 2.7l. Mileage is 126k. It's been serviced by a friend, who runs his own mobile mechanic business. Already done the following last 2+ years -
    1. Transmission service (including Upgraded Steel Sump Kit) at Precision Auto in Osborne Park
    2. Transer case service at Precision Auto
    3. Air-Compressor upgrade by my friend
    4. Usual brakes etc
    5. Timing belt at Southern Land Rover
    It runs mostly fine, except I get a kick every time gear changes at high speed (probably a propshaft problem - that's what I figured reading about this problem on the net - might be wrong). And I am not sure whether the control arm bushings are okay or not. My friend says they are okay by visual inspection. But I am not fully convinced with just a visual inspection because since owning this from 60k on the clock we have never done anything to control arms.
    So, now I am looking for a recommendation - can anyone suggest a place or a person who can have a good look, test drive and give me an honest opinion about the control arm and propshaft - I don't want to just go to a servicing centre and then get ripped off. If the control arm bushings are fine, great. Or is there something that I can check myself - I have no knowledge about cars though.
    Thanks heaps!
    Cheers.
    Sep 2014
    Baldivis WA
    Ring Dave at Dovers Rovers in Wangara: 0894080031
    Good, honest reliable service, remember you get what you pay for.
    Shift clunks means freeplay in the transfer case and splines, and / or transmission valve body.
    Oct 2019
    I take mine to Wilf Chambers in Osborne Park
    Wilf Chambers | Jaguar – British Car Sales, Western Australia Jaguar, Landrover
    They completed the original pre-purchase inspection on my D4, the first service under my ownership and then the auto transmission service. I did the in-between 7500km service myself. However, my annual 15,000 service is due shortly and I'm going to get them to do my LCAs as well as there is a knock in the front over corrugations and bumps. The jury is out on their workmanship and price as I'm relatively new to them, but I did go to them after reading several recommendations on this forum. May be an option for you.
    Oct 2011
    Fremantle WA
    Quote Originally Posted by timgalib View Post
    Hi all,
    4. Usual brakes etc
    Thanks heaps!
    Cheers.
    DazzaTD5 a member of aulro in Riverton.
    Darren Robinson AZTECH 4x4 0418 570 305 or service@aztech4x4.com.au. Honest as the day is long and good at what he does. I can drop my car off and bus via route 998/999, which might suit you too.
    Jan 2014
    Perth Western Australia
    *At the around 100K I would not expect the spline between the trans and transfer case to be worn.
    *Its pretty low km's for the age, so its prolly been babied, so again unlikely to be wear on the trans splines.
    *Highly likely it is lower control arm bushes, they can go as low as 70K or as high as a few 100K.
    *Typically I would expect clunking over bumps on the left side and if you stab the brakes momentarily.
    *Replace the whole control arm if that is the issue.
    *The front or rear drive shafts can also flog out.
    Daz
    Jan 2018
    WILLETTON
    Thanks everyone for your recommendations and advice. Much appreciated.
    Jul 2012
    Perth- South of the River
    There is also Kevin at Rovertech in Bentley which is convenient for us Willettonians . I do a lot of my own maintenance but when the jobs been a bit bigger, or I haven't had time they have looked after me.
    Gone 05 D3 ARB Front Kaymar Rear Winch E-Diff LRA Tank Dual Battery
    Current 2015 SDV6 SE. Tow Pro Mitch Hitch Llams C/motives 70ltr w/tank 2 x comp Traxide BMS-2 x Aux 150w Solar Uniden Engel ARB drawer F/Runner rack Light bar
    Mar 2012
    Gabbadah WA
    Dovers Automotive Wangarra , for an honest and reliable appraisal .
    Mar 2016
    Quote Originally Posted by Fatso View Post
    Agree. Great work
    2007 Audi RS4 (B7)
