Results 1 to 3 of 3
Thread: Topping up the hub with one shot grease
    Aug 2015
    For the Brains trust;
    Leaking hub seal. Fraser trip, no time to replace seal. Topped up leaking hub and took the whole pack,other side only took a wee bit and wouldn't take the full pack as it was full. Could I confirm that you can't overfill the hub as the filler plug is partway down the hub? Moreover , having topped till won't take more will not cause damage??
    Many thanks
    Rolly
    Defender MY 2015 110
    Adventures so far!!
    Cape York 2016 Bloomfield,OTT(Gunshot), Frenchmans,Border Ranges, Fraser Isl,Moreton Isl, Tassie(pyengana Jeep track & Montezuma falls).1770
    JDNSW's Avatar
    I assume you are talking about the swivel, not the hub, and the answer is - no problems.
    any excess will drain back into the diff or out the leak.
