Thread: Front crank oil seal?
    Oct 2011
    Burra NSW
    Hi, Whats involved in changing the front crank seal? Mine is dripping pretty well from behind the harmonic balancer..52 80"
    Sep 2012
    Westlake ,brisbane
    This may help , it tells you how to remove the timing cover. I think the seal goes in from the back ( can't remember been a long time) it is easer to get the seal out with the cover off. s1 work1.jpg s1 timing cover.jpg list 1.jpg Seal is item 3 . Check the seal surface on the harmonic balancer you may need to fit a speedy sleeve available from bearing company's . If you take the cover , harmonic balancer & old seal to them so they can measure they should be able to supply the seal as well. Sorry about the parts list being up side down , I inverted it but it turned again,
    Hope this is of some help.
    Oct 2011
    Burra NSW
    Thanks mate,
    Thats perfect, cheers
    Quote Originally Posted by 1950landy View Post
    Oct 2014
    Northern NSW.Australia
    Hi Summiitt
    Manuals here. Free downloads.
    Land Rover Manuals
    I printed out the 3, 80inch ones. Operators manual, workshop manual and parts manual, one wet, cold day.
    1,000 odd pages.
    Paper, ink, plastic sleeves, folders, came in around $50
    whitehillbilly
    Sep 2012
    Westlake ,brisbane
    That is about the cost of one of the books
