Allow $1.5-2k for a full canvas depending on what you want. Several manufacturers are available
Service history is not usually an issue but bear in mind that you are bidding on a 30+ year old vehicle. It is bound to have some faults
Bodywork and interiors will be old/worn.
All faults are repairable by a DIY mechanic with no special tools except the gearbox which can cost up to $5k to overhaul
You will probably be up for $2k to replace tyres and rims if you don’t like the standard tyres they come with.
Good luck!!!
