Results 1 to 4 of 4
Thread: Help needed on Steering Column UP/DOWN IN/OUT motor diagnosis
    Dec 2008
    Hi all,
    My steering wheel column motors have stopped working (both at once which is odd). I have checked fuse F20 and seems to be OK. I have a GAP IID tool and don't get any relevant faults.
    Is there a way to use the GAP IID tool to check the motor operation? Or any other alternative diagnosis approaches?
    My RR is a 2012 TDV8 Luxury but I think the motors are common to all the L322 range.
    Chris
    Mar 2007
    Check fuse 23 also, not sure if this is for all models though.
    Laurie
    NSW SW Slopes
    No fuses involved on MY10-12, only fusible links 2, 3 & 4 with 3 providing power to the fets that switch power for the motors.
    The switch uses a common earth for its 4 functions so that earth could be faulty.
    Oct 2010
    Carindale, Brisbane, Qld
    I thought my motors were gone too, but I discovered if I unlocked car with my 2nd key fob that it puts thew seat and mirrors and steer column to "user 2" settings and the column moves! So, it can't be the motors? It must be the stalk? I am yet to take the column cover off to investigate.
    Now: 2005 L322 Vogue 4.4 M62TU (Black)
    Before: 2000 P38A HSE 4.6 - stately capability | 2008 Kluger KX-S | 2004 Forester | 2000 Yamaha XJR1300 | 1993 VR Calais | 1974 HQ Statesman - 308 V8 | HT | HK
