Results 1 to 9 of 9
Thread: 300tdi Boost adjustment - Thoughts?
    Apr 2018
    Victoria
    Hey fellas
    The manual for the 300tdi suggests a boost of approx. 1.0 bar @ 2500-3000 rpm, in 3rd gear travelling up a slight incline.
    I replaced my turbo 2 years ago and installed a boost gauge and since then have never managed to peak above 0.75 bar.
    Today I pulled off the manifold and shortened the actuator rod 7 full turns, resulting in a boost of just below 1.0 bar.
    Tomorrow I plan to pull everything off again and install new gaskets - I didn’t want to put a new one on yet in case I had to pull everything off again - as I understand it the manifold gaskets are meant to be single use.
    So my question is this: when I pull everything off again, should I shorten the rod a little further? What happens if I continue to shorten the rod too far?
    Thanks in advance!
    NSW far north coast
    Yep, factory should be 15.5-16.5 psi otherwise EGT's will be too high and the Tdi needs as much help as it can get.
    I'd go higher, 18-20.
    Over about 20 the composite head gasket may not take it, and you'll be moving off the conpressor map anyway.
    Apr 2018
    Victoria
    That's great thanks Rick. I'll keep tweaking.
    Quote Originally Posted by rick130 View Post
    Mar 2007
    Warwick Qld
    You haven't mentioned what your EGT's are currently.
    I would strongly recommend you do some test runs up a suitable hill, before locking in the changes.
    1999 Disco TD5 ("Bluey")
    1996 Disco 300 TDi ("Slo-Mo")
    Apr 2018
    Victoria
    I hear your point Don.
    Prior to adjustment the EGT would typically read:
    400ºC cruising at 100km/h ("cruising" defender style - about as quiet as a single engine cessna )
    600-620ºC struggling up a long incline in a headwind
    I haven't seen the gauge read any hotter than 620ºC. This might change in the summer months of course.
    Following Rick's advice above I adjusted the rod another 4 turns (11 in total) and this has effectively shortened the rod 10mm overall. The boost now reads 1.0 bar (originally 0.75 bar) @ 3000 rpm, 3rd gear up an incline, and temp still sitting below 600ºC.
    Due to current restrictions in Victoria i'm unable to get to any decent roads to really test it out but will do and report back.
    Quote Originally Posted by donh54 View Post
    Mar 2007
    Canada
    There is really no point in increasing the boost unless you are also going to increase the fueling. You will have less power now than before.
    Apr 2018
    Victoria
    Really? I think the boost was underperforming from when the new turbo was installed and I thought shortening the rod would at least return it to spec?
    And yes, next step is to adjust fuel.
    Quote Originally Posted by Red90 View Post
    Mar 2007
    Canada
    Adding more air only robs power unless you add fuel with it. You might have gotten a bit from the boost compensator but probably not much. If you are not getting much more than 600 EGT your fueling is quite low.
    Apr 2018
    Victoria
    A little update for anyone following this thread...
    On the actuator rod there were originally 13-14 threads visible, and I was getting 0.75 bar (10.9 PSI) @ 3000 rpm (EGT cruising temps of approx. 400ºC).
    I then shortened the rod so there were 4-5 threads visible, and this brought my boost to 1.2 bar (17 PSI) @ 3000 rpm (EGT 400ºC).
    I figured this might be putting a little too much pressure on an engine that's approaching 400,000kms so lengthened the rod to 5-6 visible threads. This now creates a max boost of 1.0 bar (14.5 PSI) @ 3000 rpm.
    Since making the adjustment I've given the FIP screw a quarter turn and EGT remains sitting just over 400ºC (450ºC if I really push it).
    Performance wise I haven't noticed much of a change around town but was able to get on the freeway today and definitely noticed an acceleration difference when travelling 80 - 100kms.
    When the restrictions ease I'm looking forward to trying it out on some long and steep highways. This is where the old boy has really struggled in the past.
    Thanks again AULRO for all the advice and feedback!
