Results 1 to 10 of 16
Thread: Restricted performance 2011 3 liter D4 235,000 kls
    Mar 2007
    Hi there
    There may be a place to reveal the info I need but I can't find it.
    My D4 randomly drops into restricted performance, only when towing a trailer either loaded or not. I don't recall it doing so without a trailer. As an aside the trailer is not recognized by the car as it (trailer) is all LED lights.
    My local L/R mechanic has put his computer on it and it comes up with a turbo related problem. I have had the oil line mod done a few years ago.
    I do give it a bit of a flogging with 150/160 kph on our back roads so I don't think its a DPF problem. Sometimes I think it's running rough before it does the restricted performance bit but it's generally on the same piece of **** Qld highway (south of Gympie) which is notorious for vibes. Having said that it did the same thing on the way to Coffs Harbour with a trailer load of wood.
    Each time it happens I pull over, turn off and wait the required 3/4 minutes and normally the problem has gone and off we go.
    Last week I towed a horse float, empty, and the problem popped up. Stopped and did the wait bit, continued and picked up the mare, no small horse. Drove home at 90/100 kph because of the horse and no problems at all!
    Since then I have put the boot in a lot with full throttle to 140ish time and time again. Still goes like **** off a shovel and no lights!!
    Question is :
    What should I look at before the turbo!! Lots of money to remove/replace.
    Tks
    Trackless
    Could be many things I guess, you don't quote an error code. Nonetheless since you says it occurs only while towing check over your vacuum system thoroughly before deciding it really is a turbo problem.
    My experience Fault code P2263-22: Turbo System
    2024 RRS on the road
    2011 D4 3.0 in the drive way
    1999 D2 V8, in heaven
    1984 RRC, in hell
    St Helena,Melbourne
    4.28 MB
    Pretty sure you don't have a dpf and I would think you really need some live data, someone in the copilot seat with a diagnostic tool.
    2004 Jayco Freedom tin tent
    1998 Triumph Daytona T595
    1974 VW Kombi bus
    1958 Holden FC special sedan
    Sep 2014
    Baldivis WA
    Being a 3.0 D4 you have two turboes....
    Check vac lines and yes, DTCs would be great.
    Intermittent faults like this are likely to be the solenoids that actuate the turboes, or the air control valve between primary and secondary, or the turbo wastegates. At 240000km, the turbines have done a lot of work.
    And no you dont have a DPF unless its a grey import. All AU D4 of that year were not fitted with DPF.
    Nov 2014
    Nirvana near Albany W.A.
    check for any sign of oil spray underside of engine cover above intakes
    Mar 2016
    Ok. Forget checking anything until you have codes from the computer. There are endless issues that can cause it and you’ll be here until Christmas v guessing
    2007 Audi RS4 (B7)
    Nov 2014
    Quote Originally Posted by discorevy View Post
    Quote Originally Posted by DiscoJeffster View Post
    Call it an educated guess , I'm well aware there is a myriad of issues on the 3.0 litre , but sometimes believe it or not , as long as you have eyes , there are still things you can physically check as well.
    Brisbane, Queensland
    Some easier to check/fix items that might cause this problem:
    - sticky turbo actuators;
    - small split in turbo hoses;
    - sticky butterfly valves.
    L322 tdv8 poverty pack - wow
    Track Trailer ARN 200-117
    REMLR # 137
    Brisbane,some of the time.
    Quote Originally Posted by rar110 View Post
    Small crack in inlet manifold?
    josh.huber Guest
    Edit, my response was in the wrong thread.
    You can get your partner in the car. Left foot on brake right foot on throttle in drive and stall it up. That'll at least help you find a leak if there is one
