Thread: EAS COMPRESSOR TEMPS.
    SpyCar Guest
    Hello Gents/Ladies..
    Having recently rebuilt my entire EAS system.
    EAS Valveblock rebuild
    New EAS compressor - Due to replacement dunlop pump failing spectacularly!
    New Height sensor which caused a "valve stuck fault" quite irritating that!
    And having checked all lines she is 100% air tight!
    However my paranoia after a raft of EAS faults seems to have latched onto the EAS compressor and it's running temps..
    After a good drive the compressor is usually quite warm, I can hold it with my hand but it isn't "cold" other times it can be hot to the point extended contact with my hand will cause discomfort, I ran an IR thermo over the compressor after a few up and down cycles and it was at 68c..
    Am I being a nutter expecting it to stay cool?
    Or it it just paranoia?!
    Thanks..
    Douglas Park, NSW
    Any compressor will generate heat which is why bigger ones have cooling fins like an air cooled engine.
    Jan 2016
    Netherlands
    nah it won't stay cool mate. I do not know the temps on mine since I never measured them but close to that hot V8 and doing a lot of hard work I reckon 68c is not that uncommon.
    -P
    Adelaide Hills. South Australia
    [QUOTE=prelude;3040534]nah it won't stay cool mate. I do not know the temps on mine since I never measured them but close to that hot V8 and doing a lot of hard work I reckon 68c is not that uncommon.[QUOTE/]
    A Compressor pumping air will always be hotter than you expect. An Air con or refrigeration comp not so much because of the gas Cooling effect.
    SpyCar Guest
    Thanks gents.
    So the consensus is it'll almost always be quite warm under normal operating conditions..
    I'm guessing they get quite hot in the engine bay in Australia lol your winters are like my summer!!
    Just some left over paranoia after it leaving me on the stops a good few times!
    Quote Originally Posted by SpyCar View Post
    Thanks gents.
    It is a Land Rover so Paranoia is built in to the Purchase price. In fact it should have been shown on your invoice under'Misc. Charges'. It is usually 30% of the original Purchase Price but sometimes it is a lot more..
    Jan 2016
    Netherlands
    @4bee dang! 30%? that's a steal!
    On the other hand, since it is my health we are talking about, LR should be paying ME 30% rebate or smth...
