Yes as long as the ignition is on and hdc is turned on it works I watched the same video I think it was a big case of driver error
So I’ve been wondering about this for quite some time now and coincidentally I just watched a video on YouTube of the exact question I have. In the video, a fella was going up a very steep and rocky hill in a D4. His vehicle stalled and he flew down the hill backwards, went off the edge of the cliff, and rolled several times. When filming the aftermath, another fella in the convoy was saying that if you have your HDC on while going uphill, and your engine stalls, HDC will still work. Can anybody shed some light on this? Cheers guys.
Id suggest going out some place safe and testing it out
While HDC may still try to work with the engine off, as with normal brakes wont effectiveness drop off as vacuum in the brake system drops off.
Ok my curiosity got the better of me and as I live on top of a hill why not try it.
Driving forward down hill at 40kph - ignition off, very hard brake pedal, and when HDC is switched on - nothing as there is no power to it.
Driving forward down hill at 40kph - ignition on, and engine off, very hard brake pedal, and when HDC is switched on, it kicks in straight away and continues to work. Obviously the ABS pump by itself provides brakes pressure and no vacuum assist is needed. No vacuum assist to the foot brake but HDC continues to work well.
Driving backward down hill at 40kph - ignition off, very hard brake pedal, and when HDC is switched on - nothing as there is no power to it.
Driving backward down hill at 40kph - ignition on, and engine off, very hard brake pedal, and when HDC is switched on, it kicks in straight away and continues to work.
So as long as the ignition is turned on and HDC is selected - HDC works forward and backwards even when the engine is not running.
 Master
						Master
						maybe I'm misunderstanding your post (or I have the wrong idea completely) but I thought HDC worked when not brake is being applied and stopped if you put your foot on the brake.
Simply as part of the test I did - I also tested to see how quickly I lost the vacuum on the foot pedals - just highlighting that when ignition is on but engine is off you loose your brakes but HDC still works and does not need vacuum to work. Remember with HDC on and the engine running, you can still drive through it and you can still use your brakes if you want too. When driving along on a track with HDC on - it will kick in as soon as you lift the throttle but if you push the throttle down you can drive through HDC but it is still on but not activated - foot off and it kicks back in.
Personally I rarely use HDC as the constant shuddering and noise annoys me and I have found that low range, first gear where the torque converter locks and no throttle, means the car travels down very steep hills at about the same speed as the slowest HDC setting.
I never use it downhill either, for exactly the same reason. However, I switch it on for steep uphill climbs (low range of course) as an insurance policy should the engine stall. I also find that leaving the Terrain Response in Normal and selecting gears manually (Command Shift mode - everything is a "mode" these days!) works best for me and the type of terrain I cross. It's a pain having to remember to switch off Dynamic Stability Control each time you start the car and, when travelling in hilly country, to keep switching off HDC once you've finished climbing and switch it back on again as you reach the next steep climb.
Still, it's nice to comfortably negotiate the roughest tracks without spilling any champagne!
2013 D4 expedition equipped
1966 Army workshop trailer
 Master
						Subscriber
						Master
						SubscriberI realise that it is preferential to switch off DSC when sand driving but I am interested why do you do it for hilly country, and also why do you switch HDC off and on all the time?
Can't you just leave it on to simplify matters?
I've not done serious 4WDing with my D4 so am very interested in people's driving mode choices.
Before: Ser 2a LWB, Ser 3 S/W, 1979 RR 2 door, 1981 LR Stage 1 V8 (new), 1985 LR 110 V8 County (new), 2009 RRS TDV8
Now: MY13 D4 TDV6. "E" rear diff. Cambo's magic Engine & Auto Tune. 1968 Austin 1800 Mk1 auto (my 5th)
