Results 1 to 10 of 16
Thread: New Defender - 19 or 20 inch wheels
    Aug 2016
    Hi There,
    I am considering placing an order for a new Defender 110 D300 shortly ( April delivery next year ) and I am in a dilemma on which wheel size to order. Unlike my present D4 with 18" compomotive wheels, I don't really want to go to the expense of retro fitting 18 inch wheels to the Defender when available.
    So do I just settle for factory 19" wheels and put a set of Goodyear Duratrac 255/65r19 on or do I get 20" inch factory wheels with a lower profile but a far wider choice of 255/60R20 good all terrain tyres.
    Planned use for the Defender will be suburban school runs, around the farm, through rivers/creeks, occasional fire trail and the occasional day 4WD trip around Walhalla.
    Interested in all different views and thoughts.
    Apr 2012
    Whyalla, SA
    20s. Or take one of your wheels down and see if PCD is correct and they may fit.
    Oct 2016
    Perth, AU
    Or get the D250, with 18", and hope BAS or otherwise come up with a remap to bring you back up to D300 outputs...
    2010 TDV6 3.0L Discovery 4 SE remapped to RRS output, Alaska White, GME XRS-330c, IIDTool BT, Dual Battery, Apple CarPlay, OEM Retrofitted: Cornering lights, Door card lights, Power + Heated Seats, Logic 7 audio
    Aug 2016
    Wouldn't that be an easy lovely fix just to use my existing compomotives.
    Wonder what the wheel offset requirement is on the new D300 ? Assume stud pattern would be the same.
    Aug 2016
    Wheel specs on the new Defender D300
    Land Rover Defender 2021 - Wheel & Tire Sizes, PCD, Offset and Rims specs - Wheel-Size.com
    Land Rover Defender 2021 3.0 D300
    Generation: L663 [2019 .. 2021] [EUDM]
    Power: 296 hp | 221 kW | 300 PS
    Engine: I6, Diesel
    Options: Defender, S, SE, HSE, X-Dynamic S, X-Dynamic SE, X-Dynamic HSE, Defender X, Hard Top, Hard Top S, Hard Top SE, Hard Top HSE
    Center Bore: 72.6 mm
    Wheel Fasteners: Lug nuts
    Torque: 140 Nm
    Thread Size: M14 x 1.5 [/I]
    Trim Production: [2020 .. 2021]
    Tire Rim PCD
    255/70R18 116H 8Jx18 ET41.5 5x120 2.3 / 2.5
    255/70R18 116V 8Jx18 ET41.5 5x120 2.3 / 2.5
    255/65R19 114H 8Jx19 ET41.5 5x120 2.3 / 2.5
    255/65R19 114V 8Jx19 ET41.5 5x120 2.3 / 2.5
    255/60R20 113H 8.5Jx20 ET41.5 5x120 2.3 / 2.5
    255/60R20 113V 8.5Jx20 ET41.5 5x120 2.3 / 2.5
    275/45ZR22 112W 9Jx22 ET44.5 5x120 2.3 / 2.5
    Mar 2013
    Quote Originally Posted by Garfield View Post
    Unlike my present D4 with 18" compomotive wheels...
    If you're comparing your 18" wheels from your D4, you need to consider the D4 has 30" diameter wheels and the Defender has 32" diameter wheels. For the standard tyre sizes, an 18" wheel on your D4 with 255/60R18 tyre will have the same 152mm sidewall as a 20" wheel with 255/60R20. Details are in the below tyre comparison screenshot.
    If you are already ok with the sidewall size on your D4 for your planned use, then you're probably comfortable to choose the 20"option with the same size sidewall. Also, if you choose 20" then there's no need to modify the brakes on the D300 to get the 18" wheels to fit.
    As you have stated, there's far more choices in A/T tyres for 20" v 19", but there's even more choices and availability in 18", particularly in the outback.
    Aug 2016
    The KO2 's on my D4 have about 5 months of wear left. So if the compomotive rims on the D4 ( offset ET 44 and same PCD ) fit the new D300 I would replace the old tyres with new 255/70R18 tyres - to keep same rolling circumference i.e. 32". I still have the original wheel/tyres off the D4 - so I'll refit them to the D4.
    But ultimately I'll just need to physically trial fitting the comompotive on the D300 hub.
    SBD4's Avatar
    SBD4 is offline A Keeper of the TGO Gold Subscriber
    Dec 2011
    Bundeena
    This doesn't directly address your question but....This bloke is a POM in Canada who has recently started posting about his new defender. He's green oval fan and owned a number of LR Models. He's been doing a few vids and this one about trying different LR rims. Interesting exercise and some good views of clearance issues etc.
    If the GOE's don't fit you could take the tyre size up 1/2" to 1" on the 20s to get a bit of extra sidewall.
    Anyway he does love a "chat" but that's good because you find out stuff like the fact that the EPB release is in the engine bay (found in the oil change vid):
    Sean
    Aug 2016
    Thanks Sean. I think the main issue is the compomotives rims fitting over the front brake calipers of the new Defender D300 ( not so much the tyre size itself) - which we will only really know when we try it out.
    P.S. The guy in the vid could" talk under water with a mouth full of marbles "
    Quote Originally Posted by SBD4 View Post
    SBD4's Avatar
    Dec 2011
    Bundeena
    No probs, the reason I thought the vid might be interesting is he has some good close ups of how the various rims fit and what obstacles you might encounter when trying different rims. Looking at the vid from 16:35 he shows what would stop you from fitting the GOEs or any 18s for that matter. I wonder if, whatever it is, can be removed. Probably should have given you the simetamp upfront to save you some time . BTW his is a P400.
    Sean
