Thread: Solar Blanket
    May 2009
    Tatura, Vic
    Solar Blanket
    I wish to purchase a solar blanket.
    They can vary greatly in price from $150 to $600.
    The $150 is a Kings brand and is water resistance, not water proof, so this is getting a big miss.
    Kings 200W Portable Camping Solar Blanket | Regulator | Cables | Alligator Clips - 4WD Supacentre
    Then there is ones like this for $429.
    BAINTECH 110w Flexi Panel Across Google&utm
    I don't mind how much I spend. I just don't want to spend more than needed, Eg. if a $250 one was just as good as a $400 one
    Anyone have these or have a good knowledge that can advise me?
    Dave.
    I was asked " Is it ignorance or apathy?" I replied "I don't know and I don't care."
    1983 RR gone (wish I kept it)
    1996 TDI ES.
    2003 TD5 HSE
    1987 Isuzu County
    St Helena,Melbourne
    4.28 MB
    I have only purchased 2 solar panels, a 120w rich folding and a 125w companion blanket. Both around $150 SMF both with similar output, I would work out what type is more suited to your use. The semi flexible panels are ideal for mounting or hanging off a roofrack and the blankets are easier to store.
    2004 Jayco Freedom tin tent
    1998 Triumph Daytona T595
    1974 VW Kombi bus
    1958 Holden FC special sedan
    If you really do wish to purchase a solar 'blanket' then the BainTech one you link to does not look like a 'blanket'. It's a flexible panel but does not look like it folds to a small packet like the Kings one will.
    2024 RRS on the road
    2011 D4 3.0 in the drive way
    1999 D2 V8, in heaven
    1984 RRC, in hell
    Apr 2019
    Quote Originally Posted by Ferret View Post
    Agree, BainTech is semi flexible and defiantly doesn’t fold.
    Jan 2017
    Geraldton WA
    I am not aware of Any solar blanket on the market (regardless of price) that is fully waterproof.
    It isn't the panels that are the problem its the wires/connections that join all the different panels together that corrode and fail when affected by moisture for any length of time.
    You can get the blankets wet (the odd rain squall or a dewy morning) occasionally But it is imperative that they are dried out especially for storage.
    If you are after something that is better suited to a damp/wet environment the stick to the flexible/ridged panels with waterproof connectors.
    I am a fan of the solar blankets myself because they can be stowed away in a small area But only as a backup option on a long trip or as a "weekender" option.
    For reliable solar power in pretty much Any weather I personally prefer the ridged panels over the blanket and the flexible panels because the ridged panels allow for a decent air gap between the panel and the mounting surface that helps to prevent the panel from overheating and loosing its output.
    4.6m Quintrex boat
    Aug 2018
    I went through a similar process or wondering whether it was worth spending a lot or a little for relatively infrequent use.
    I ended up going with a HardKorr 200W blanket, they introduced a 'budget' range a few months back, however the specs etc are the same as their 'premium' range. I've been very impressed, well made and does the job, only criticism is that they don't supply any instructions with the controller to explain it's features. They sent some over after I called, but they aren't much use.
    D4 TDV6 MY15, Llams, 18" Compos, BFG KO2's, REDARC DBS, Rhino Platform & Mitch Hitch
    Previously;
    Aus - '05 D3 TDV6, '08 D3 TDV6
    UK - '96 D1 300TDI, '95 Def 90 300TDI, '92 Def 110 200TDI, '95 D1 300TDI, '04 Freelander TD4, '
    88 90 2.5n/a, '95 D1 300TDI
    Apr 2019
    Quote Originally Posted by M005 View Post
    Re: controller, some of the lower end ones are not much chip, I removed mine and installed a brand named Bluetooth controller near the battery.
    Apr 2012
    Whyalla, SA
    So those with blankets - what is the rating and what have you seen out of them so far?
    Jan 2017
    Geraldton WA
    I have a small 120w redarc blanket hooked up to a 115AH deep cel battery that i have used over the last couple of years and it can run a 38l engle fridge set at -2C without any dramas whatsoever.
    It charges at between 4-6A (depending on the weather) and the fridge only uses about 3.5A about every 20min each hour so it doesn't put any pressure on the battery and in the morning even on a hot night the battery never gets below about 75% SOC.
    I did dump the solar controller that came with the blanket and use a MPPT controller instead But otherwise It works as advertised
    4.6m Quintrex boat
    Apr 2019
    I forgot about this thread.....
    If the cloud lifts I’ll get the solar blanket out and check it’s performance.
