Results 1 to 10 of 19
Thread: IIDTool - Leave connected?
    Jun 2019
    Montrose Victoria
    Have just received my Gap IIDTool, thanks Matts59, the introduction/warnings piece of paper that come in the box mentions it is not designed to be left in place for long periods.
    What is the general view on this? If I were on an extended outback trip I would be inclined to leave it there plugged in for the entire time, probably just leave it there even when back home, or is this a bad idea.
    regards
    Geoff
    Kallangur, Brisbane
    Mine has been connected permanently for close on 5 years now.
    + 2016 D4 TDV6
    Dec 2009
    Ranelagh, Tasmania
    I've had two Bluetooth modules fail now. Not so bad on the D4 with the instrument cluster display but no good on the RRS. I'm thinking I won't leave it connected full time for the next one.
    Fuji white RRS L494 AB Gone
    2023 Ford Ranga
    Apr 2012
    Whyalla, SA
    Heaven forbid the designer/manufacturer would know the limits of their hardware IIDTool - Leave connected?
    Jun 2019
    Montrose Victoria
    Is that a bit like saying "our product is the best thing ever you will never need to buy anything else"
    I was just asking what people are doing in general with their IID tool
    regards
    Geoff
    Oct 2011
    Fremantle WA
    Quote Originally Posted by OldGuy View Post
    regards
    Geoff
    Maybe I'm reading too much into it, but I took it that Mike was saying follow the manufacturer's recommendation
    (from someone who does forget to remove it now and again and usually uses it as an instrument gauge on trips and/or towing). Cheers
    Apr 2012
    Whyalla, SA
    It would depend on the manufacturers design criteria and components used. If they built the tool using components designed for infrequent use then by leaving it connected you are shortening the design life significantly.
    As most diagnostic work is 20-30min, running it 24/7 is a significant increase in duty cycle and will obviously have an impact on component life.
    Not my property, not my issue.
    Jun 2019
    Montrose Victoria
    Not my property, not my issue.[/QUOTE]
    That seems reasonable am planning on using my gear, no one elses'
    May 2014
    Point Cook, VIC
    If you do leave connected, make sure you disconnect from the phone Bluetooth when not using as the power drain is high when connected.
    Also consider locking to your device, an open Bluetooth OBD2 device can be a security issue if left connected to the port as it can be connected to by anyone from outside your car. Not an issue in remote areas, but could be in major city centres. The Gap tool is very powerful - unlike other devices which can only read information.
    I have another OBD adaptor (OBDLink Mx+) which I do often leave connected but it is paired securely to only a few devices, only has read access, and goes into full sleep mode when the engine is off. Unlike the Gap tool it is designed to be left connected.
    Jun 2019
    Montrose Victoria
    Thanks DiscoDB, good points re locking the device and disconnection of bluetooth. We have a fairly lengthy 3 to 4 month trip planned next year and will be towing. Will probably leave it connected for the journey to keep an eye on temps with the above provisos in place, then leave it in the drawer until needed. Hopefully not until the next trip...
    regards
    Geoff
