A common issue that gets reported is the bonnet switch. This can be bridged out to prove if that is, or isn’t the problem.
ok,
damn alarm keeps going off randomly after locking... seems to be just random ... after an hour or so - some times less, sometimes more
Is there a way to check whats setting it off? or something I should look at?
Appreciate any ideas
 Wizard
						Subscriber
						Wizard
						SubscriberA common issue that gets reported is the bonnet switch. This can be bridged out to prove if that is, or isn’t the problem.
2014, MY14 Discovery TDV6, Fuji White (2018-Now)
2003, Discovery 2a, Td5 Manual, Zambezi Silver (2012-2018)
2007, Adventure Offroad Campers, Grand Tourer (2015-Now)
I had the same issue on my 3. Was the bonnet. A new lock mechanism fixed it. Guess the old one was worn and didn't hold the bonnet tight enough.
Gone 05 D3 ARB Front Kaymar Rear Winch E-Diff LRA Tank Dual Battery
Current 2015 SDV6 SE. Tow Pro Mitch Hitch Llams C/motives 70ltr w/tank 2 x comp Traxide BMS-2 x Aux 150w Solar Uniden Engel ARB drawer F/Runner rack Light bar
First time cleaned the bonnet switch contacts. Good for about a year. Second time bridged contacts with a paper clip. All good ever since.
MY08 TDV6 D3 Zermatt Silver, B.A.S ECU Remap, ARB Bar, 12K Kingone Winch, 2x100Ah LiFePo4 Auxiliary Power, Safari Snorkel, Baja Rack Roof Rack, Brown Davis Aux. Tank, RWC, Front Runner Rear Ladder, Drifta Drawers, Doran TPMS, LLAMS, GAP IID BT.
Had mine go off a few times even though bonnet switch bridged. I think mine is the rear RH door latch. Alarm hasn't gone off for a while but a couple of times I have closed that door but the dash shows door open. Door definately closed.
Damn it! Have probably jinxed myself now.
There is no eraser on the pencil of life.
Now - Not a Land Rover (2018 Dmax)
Was - 2008 D3 SE 4.0l V6
Was - 2000 D2 TD5 with much fruit.
Ray
