Results 1 to 3 of 3
Thread: Window Clunk
    Nov 2020
    Newcastle
    Window Clunk
    Hey Gang,
    I’m a brand new owner of a 1995 P38 Rangie which I am becoming very attached to, this thing is so much fun. But I am in the process of learning, reading stacks of maintenance manuals, and trying to figure out my Fault Mate diagnostics tool. What I have noticed early on (and I would love some advice from the experienced RR/LR owners) is a clunk on the wind up on my electric window. Is this simply a replacement of the motor/regulator located inside of the door itself? I’ve heard teeth wear out on these eventually.
    Thanks in advance for your help.
    Regards,
    Jace
    4X4V8 Guest
    Quote Originally Posted by Jace.Ward View Post
    Hey Gang,
    Regards,
    Jace
    I replaced the regulator in my driver's door when I bought the car, as it had a few broken teeth and was clunking. Don't assume it is that, might be the nylon guides? I don't know, but my money is on the regulator. Best thing is to take the door card off and have a look. It was around $100 for an aftermarket replacement reg I think. Not a hard job, except you need to drill out the rivets that retain the regulator if it's a front door (rears might also be held on by rivets but RAVE suggests that they are bolts). I've heard of people replacing the rivets with nut/bolts, I just got new rivets.
    Oct 2007
    Williamstown, Victoria
    I was driving along once and heard a very loud bang, i thought it was a rock thrown at the car! But then realised the window regulator had broken when the window didn't move.
    I have replaced my drivers door regulator twice over 10 years, the teeth do wear out over time.
    Yours could also be a loose bolt or rivet, probably a good idea to remove the inside door trim and have a look at what's happening while you operate the window up and down.
    Not a hard job, I replaced mine using stainless steel rivets to prevent rusting.
