Results 1 to 10 of 12
Thread: More Diesel drama's
    Sith Guest
    More Diesel drama's
    Ok need some input/help from the guru's please !
    I have a 1992 RR with a 300tdi conversion done , I have had drama's in the past few months with vaccumm locks in the tank which the lines were blown out and new tank cap fitted up ect ect .....here comes the new drama .....
    Ok on any gradiant over 15 degs from a stationary position in 1st gear high range on the tar mat , she will stutter and stall ... re start and get the rev's up and try again ... now with the rev's at say 1200 and let out the clutch the revs drop immediatly to around 400 then stutters and heads off ... thru all other gears no drama's ..... going up hills [big hills] towing a trailer no drama ... the minute i come to a complete stop the drama's start again !!!!!!
    On a flat ground stationary start ... no drama at all
    all help appreciated
    SYDNEY -in the shire.....
    what happens if you try it in low range....?
    the symptoms lead to letting the clutch out too quick....maybe a fault with the clutch....?
    if it was fuel it would do it in all gears at the same revs i would think....?
    check to make sure all the plumbing on the inlet side of the air intake is connected....including the turbo.....
    Apr 2002
    Godwin Beach 4511
    32.43 MB
    lift pump on the way out... ?
    2007 Discovery 3 SE7 TDV6 2.7
    2012 SZ Territory TX 2.7 TDCi
    Sith Guest
    thanx for the replies guys will be starting to check everything over tomorrow ....also just going thru my logg books since i had it and noticed i have dropped off about 70km per tank
    Buggar
    td5130 Guest
    I would Try that vacume thing on top of the injector pump its sposed to stop it over fueling when no boost may be it not working broken dirafram or hose come off
    Somewhere else, QLD
    Tdi
    Howdy: I've a 300Tdi, and have had similar symtoms -
    Apart from the fact that a 300Tdi when cold and without boost has a hard time doing anything, there are some things you can do to keep it doing it's best.
    1. Check the turbo hoses, intercooler and inlet hoses, air filter and inlet manifold. When you lose air pressure, then performance suffers. Wash the intercooler out with a good degreaser, Replace the jubilee clips with HD clips from CBC. If there are oil stains from under the inlet manifold, get another gasket ($20), or check to see if there are any broken manifold bolts ( replace with M8 fine thread HT) . Check to see that the connections off the turbo to the injector pump are OK.
    2. Use a decent injector cleaner.
    3. Use a 12mm or 11m drill with 3/8 shank ( in place of the LR timing tool) (Tape the sharp edges) and check the timing's right.
    If those things don't fix it - get serious and check the timing belt, crank pulley and woodruff keys.
    Langy
    Sith Guest
    Ok i run redline diesel fuel conditioner every tank , but ...... had a look at everything today ...timing is right ......timing belt done 12000km ago .....and i have an air hiss sound around the pipe from the turbo to the intercooler ....around the intercooler area .... all clamps are tight ... so at this time i still dunno ?????
    the pipe from the intercooler to the turbo looks to be steel exhaust pipe with a rubber hose over it .
    Air filter is new [1000km] but the air filter box is loaded in drill holes 50mm holes from the previous owner and i have been tryiong to source a EFI RR air filter cylander shaped one so i can get a snorkle down the track .....
    May 2002
    Sydney, Australia
    Certainly sounds like your loosing boost somewhere - I'd track down that hissing if I were you.
    Also check all intercooler hoses - they have a tendency to break down and delaminate after a while.
    HTH
    LRH
    Disco 4 SDV6 Auto
    Disco 4 SDV8 Dual Cab Project
    Disco 2 M57 Extra Cab Project
    Foton Tunland Cummins ISF
    Disco 1 3 door 4.6 V8 Auto
    RRC V8 Auto "Classic" Softdash
    RRC 300 TDI Auto
    Disco 1 TD5 Auto Buggy
    Disco 1 300 Tdi Auto Ute
    SAME Explorer 70HP 4x4 Tractor plus Nell Loader
    Subaru GDA WRX
    Triumph Bonneville SE
    Yamaha TTR250
    Conversion Cost
    Sith, was the car done or did you get it converted. I am thinking of doing my old 2 door to diesel, its a range thing, not $$ for fuel but the 400KM to the tank that annoys me.
