Results 1 to 10 of 19
Thread: Puma factory radio
    Oct 2013
    Richmond, NSW
    Puma factory radio
    Hi team
    Has anyone replaced the factory radio in their Puma and now have this and PIN ‘surplus to requirements’?
    I am looking for an original Land Rover unit to install in my Td5 as the original radio is slowly dying.
    Cheers - Simon
    Travelrover
    Adventure before Dementia
    2012 Puma 90 - Black
    1999 Td5 110 Ute - White
    1996 Tdi 300 Wagon - White
    Jun 2007
    Margaret River
    Ive got one Im willing to part with out of my 2012 130 Puma
    Complete with code and aerial adaptor
    PM sent
    Oct 2013
    Richmond, NSW
    Quote Originally Posted by Grappler View Post
    PM sent
    Thanks Grappler, unfortunately my mailbox was full so I didn’t receive your PM. Have cleared it now so if you could resend that would be great!
    Cheers - Simon
    Travelrover
    Huntly via Bendigo
    I also have but looks if you are ok. I took mine out due to a crappy land rover radio I put a Kenwood in its' place and I get much better reception when the original would not work.
    Lindsay
    Oct 2013
    Richmond, NSW
    Quote Originally Posted by oldyella 76 View Post
    Lindsay
    Thanks Lindsay
    Yup all sorted now ;-)
    Cheers Simon
    Travelrover
    Oct 2013
    Richmond, NSW
    Ok I have my ‘new’ 2012 Puma radio and looked Puma factory radio at installing it this morning in the Td5.
    Unsurprisingly the plugs are quite different.
    Am sure I read somewhere on here that there is an adapter cable that will fix the problem available from one of the regular accessory outlets...
    Standard Td5 plug
    New 2012 Puma plug...
    And this cable was in the box...
    Has anyone had experience swapping these units? Is there an adapter available off the shelf, or do I need a trip to my local sparkie?
    Thanks in advance.
    Cheers Simon
    Travelrover
    Dec 2008
    Tewantin, Qld
    I'd start with a call to your nearest car sound place, they usually have an extensive catalogue of the things.
    I've used my local Car Sound a couple of times. You will need to give them the make, model and part number of the old and new units.
    Cheers Glen
    Yass NSW
    Aerpro seem to make most of the adapter cables that are available - Link to site Landrover Defender 2007-2015 | Aerpro
    The factory cable on the later Pumas is a native cable to suit Alpine headunits and looks like the white plug on this cable Alpine CDE-133EBT | Aerpro
    If the adapter cable above fits you are good. The Aerpro site says that the cable in the second link works for a range of Landrovers with single DIN radios such as Disco 2 and Freelander as well as Defenders
    The other way to fix it would be to splice the connector that comes with the radio into the TD5 harness which should not be too difficult.
    Regards,
    Tote
    Oct 2013
    Richmond, NSW
    Quote Originally Posted by Tote View Post
    Regards,
    Tote
    Thanks Tote
    I was looking at those in Supercheap yesterday, but they had a pretty limited range. I called my local auto sparkie and it was all a little hard for him, he wanted to see circuit diagrams but I can find any for the Puma.
    Cheers - Simon
    Travelrover
    Yass NSW
    Quote Originally Posted by travelrover View Post
    Thanks Tote
    Cheers - Simon
    If it was me I'd order the connector cable that they suggest (or if you can find it locally pick one up) and take a punt that it fits, if the plugs work the wiring should be good. The manual for the head unit should have the wiring diagram in it, if not I can probably fined one from one of my Alpine units.
    Regards,
    Tote
