I undone the front one by jacking the car up as far as i could go,put the breaker bar on a car stand and let the jack down,All done from behind a brick wall in case something gave way.Perhaps you could hire a torque multiplier from somewere.
Hi All,
Started a long overdue replacement of the LH rear hub today - until I got to undo the stake nut. 500 mm breaker bar with my full, not-inconsiderable weight standing on the end made no impression on it. Nor does a 600 mm length of water pipe on a sliding tee-handle (except for starting to bend the tee-handle bar).
So most knowledgeable ones, how do mere mortals shift these things please? Will a rattle gun move it? (Neighbour has one, but is away today.) Really don't want to put it back together with the greasy old undersized disc and worn-out pads to take it somewhere if it can be avoided. Thanks.
Ian &
Leo - SIII 109/GMH3.3
Daphne I - '97 Disco 300Tdi Manual
Daphne II - '03 Disco Td5 Auto
Darwin
03 disco 2a td5
93 tdi disco [gone to a better home]
2003 d2a v8 retired hurt
1988 k100rs bmw gone
85 county izuzu [gone to a better home]
69 series 2a [gone to a better home]
series 2a [gunnado]
series 3 [gunnado]
and the tinny
There is a neat, even if I say so myself, wheel nut torque spreadsheet.
http://discovery2a.com/Resources.html
100kgs at 500mm is 490Nm of torque. If you are more than 100kgs then it should undo. The torque for the hub nuts is 490Nm.
Build date 11th Oct 2003
LROCV #1410
if its the stake nut version...
unstake it first.
I just use my milwaukee gun does 1400nm nut busting torque
03 D2a Manual Td5 Modified, Ashcroft lockers F&R, Ashcroft R380,Atb lt230, Ashcroft Rear axles, AS manual IC, AS exhuast manifold, AS Coolant bottle, 3inch exhaust, alive GTB550 VGT, billies 7100s, 3inch lift, 4inch staino snorkel, 35s beadlocked
JayTee
Nullus Anxietus
Cancer is gender blind.
2000 D2 TD5 Auto: Tins
1994 D1 300TDi Manual: Dave
1980 SIII Petrol Tray: Doris
OKApotamus #74
Nanocom, D2 TD5 only.
Yes, definitely unstaked! It's not a left-hand thread on the LH side, is it?
In any case, I've tee-ed up with the local tyre place to rattle it loose on Friday arvo, then nip it up tight enough for me to drive the 600 m home to have another go at the job this weekend.
Ian &
