Results 1 to 10 of 24
Thread: SRS light On!!
    May 2015
    Williamstown, Victoria
    SRS light On!!
    This is giving me the irrits. I have taken apart the yellow plug and sprayed with contact cleaner. It is the same. Light stays on.
    Options? Hard wire across the plug?
    To me it seems stupid having it hang of the seat as the yellow end goes to the DCU. Surely this wiring could have been routed under the console?
    added
    The cables are black and white and purple and white and these do not go to the DCU. Where do they go? The hunt is on.
    Build date 11th Oct 2003
    LROCV #1410
    Jul 2014
    west of Transylvania
    First of all what's the fault code which made that plug suspect ? If the code was about the pretensioner there are no BW and PW wires involved unless you mean the wires into the female plug which are coming from the buckle. What's the exact fault code ?
    Apr 2016
    Country Vic.
    Quote Originally Posted by Bohica View Post
    Whilst waiting for more info on this ...
    have you checked fuses?
    If not, try Fuse 35 in the drivers side panel(10Amp) .. also connected in the SRS system is Fusible Link 8(50Amp) in the engine bay fusebox.
    Arthur.
    '03 D2 Td5 Auto
    '03 D2a Td5 Auto
    May 2015
    The fault code is
    "CODE 032
    The right hand pretensioner measures open circuit
    (Intermittent)"
    It looks as if the BW & PW cables go to the pretensioner. The cable heads that way.
    And. I am guessing that since the solvent has all evaporated, the solvent is not causing an open circuit. The SRS light goes out and stays out.
    added
    A longer drive and the same fault appears. Cleared this with the Nanocom, maybe time for a new plug as I do not want to hard wire the connector.
    LROCV #1410
    May 2015
    Quote Originally Posted by AK83 View Post
    The fuse is good, so is the fusible link, checked with a multi-meter.
    The code changed to permanent was cleared with the Nanocom back to intermittent and cleared again to no fault.
    I can't help but feel that it is the yellow plug that is faulty, ans as the cushion is loose, easyish to replace the plug.
    LROCV #1410
    Apr 2010
    South Melbourne
    Have you checked the yellow plug behind the glove box as well?
    When I get the SRS light I just unplug and replug both, and the light goes away next re start.
    May 2015
    I didn't know there is a yellow plug behind the glove box! What gymnastics are needed to access it? Or do you just remove the glove box?
    Would it get wet if water came in through the windscreen plenum?
    LROCV #1410
    Jul 2014
    Neglect the plug behind the glovebox cos it's for passenger's airbag, as long as the fault code is for the RH pretensioner your only problem is on that particular circuit no need to check anything else.
    Nov 2018
    Men, my td5 has exactly the same "feature". I got it from previous owner who said it was like that from the previous owner. I never mind it but good to learn more and if anything we can fix it that's good too.
    Sep 2010
    The Hills.
    152.79 MB
    Quote Originally Posted by maxperformance View Post
    Here in Vic it would fail a RWC.
    ​JayTee
    Nullus Anxietus
    Cancer is gender blind.
    2000 D2 TD5 Auto: Tins
    1994 D1 300TDi Manual: Dave
    1980 SIII Petrol Tray: Doris
    OKApotamus #74
    Nanocom, D2 TD5 only.
