Results 1 to 6 of 6
Thread: new A/C comp
    Jul 2019
    buderim
    new A/C comp
    had a leak, al, it was were the seals on the hp pipe to comp
    LR comp 3599
    M and R Bris 1550
    UK via ebay 850 inc shipping here in 4 days
    seeing as I suffered a stroke and have only one useful hand, I had British off road do the swap, 7.5 hrs at 125/hr
    d4 has 211000 km, lots of money spent by second owner, however he put poor rubber on for the roadworthy, which cost hours out in the bush, driving into a village on shredded tyre. spare on the 5 new AT'S on in Emerald QLD
    I sunk into a very deep dry sand hole few weeks back, had the tailgate up and when a kind man snatched me out I ran into his ute, wrecked my gates no damage to his
    suffice to sat my face was red as i spent my life around heavy plant
    i managed to build this since my stroke, going to NT
    Jul 2019
    buderim
    OLD COMP IS GOOD, WILL sell at very reasonable price
    josh.huber Guest
    At 211k that compressor is ready to be turned into coke cans
    Jul 2019
    buderim
    Quote Originally Posted by josh.huber View Post
    whatever you think, lovely post from you
    josh.huber Guest
    Quote Originally Posted by stuarth44 View Post
    Sorry if you took that the wrong way mate, they are a common fault item, they often to do well get to 200ks I just did mine at 250 and when it was cooling it seemed ok. But compared to a new one it was completely dead. I did a full flush on the system and it was full of grey death, which is the compressor failing. Being an 8 hr job I just didn't want someone to have to fit it twice
    Ocean Reef WA
    I had the aircon comp go on the Puma at around 120K. Or I should say the incompetent mobile aircon mechanic said it was leaking slightly from the front seal behind the pulley. So off it came and all seals done.... except the outside front seal which keeps lots of dust out. Why? They didn't have one in stock!!!
    I bought a replacement off TR (from memory, such as it is) and had that fitted.
    Then he stuffed something about so much, flattened the battery and so on I told him to shove off.
    Got the stealer to fix it and 3K later all was well. Not the compressor after all but the valve on the evaporator or something. Now I've got the original comp in the shed with new seals except for the front one.
    Anyone interested? Offers anyone?
    AlanH.
