Results 1 to 10 of 13
Thread: Nanocom Readings
    Brissy! No flannos here!
    Nanocom Readings
    Thought I'd throw this out there for discussion and comment.
    I built this D2 TD5 primarily from donors, so very little and very few of the components are new.
    I started looking at stuff because occasionally, it won't pull the hat off your head until 2100RPM, which is not uncommon for a TD5, but in this case, it sometimes struggles to get to 2100!
    Anyhoo, what y'all think of these numbers?
    For perspective, the peaks were obtained at about 3000- 3200 RPM.
    With ambient approx 100, that makes the boost about 116 kpi or 16.5 psi.
    SB001.CSV
    Jun 2013
    Universe A
    Quote Originally Posted by Ralph1Malph View Post
    Can you post the log?
    Quote Originally Posted by shack View Post
    Done. It's short as I tried to capture the problem.
    Perth WA 6149
    Off the top of my head with a glass of red wine in hand I reckon the airflow readings are a bit low, so unplug the airflow sensor and see if that makes a difference. If so then you’re probably up for a new airflow sensor as the old one is on the way out.
    Alternatively try cleaning the sensor but only do it when it is stone cold and be gentle as the filament in the centre is delicate. Use either airflow sensor cleaner or contact cleaner.
    Steve
    Quote Originally Posted by Rok_Dr View Post
    Steve
    I believe I have some cleaner, I'll give it a go. I also have a second MAF from a donor, but can't vouch for it's condition.
    Jul 2014
    west of Transylvania
    For a clear view you should attach the table where the values are clearely shown in columns not that graph
    Perth WA 6149
    Tap on the SB001.csv link above the graph
    Quote Originally Posted by sierrafery View Post
    Cheers Steve
    Jul 2014
    Cheers Steve
    Sorry, i missed that, in those readings two things are obvious, the air flow is too low under load, and the IAT side of the MAP/IAT sensor is all over the place, I'd replace it with a new one then try with unplugged MAF and if it's better that one too
    Okies, swapped out the MAF for my donor car MAF (after a clean).
    I also noticed that after I did the EGR delete, I didn't remove or cap the blue vacuum line from the valve to the modulator.
    I think it runs a bit better, here's the file:
    SB002.CSV
    RJ
    Jul 2014
    This MAF is worst than the other, a good MAF should show 55-60 at idle and go to around 600 at full boost
