Could be.
Search says
Just a moment...
Cruising along suddenly cruise control drops out m&s lights and d light are flashing. I have drive and reverse only. Seems I only have fourth gear with no converter lockup. Code po705,is this the xyz switch
Darwin
03 disco 2a td5
93 tdi disco [gone to a better home]
2003 d2a v8 retired hurt
1988 k100rs bmw gone
85 county izuzu [gone to a better home]
69 series 2a [gone to a better home]
series 2a [gunnado]
series 3 [gunnado]
and the tinny
Could be.
Search says
Just a moment...
Build date 11th Oct 2003
LROCV #1410
Mark F...
Vk3KW
2002 D2 Td5 auto - current AKA The Citrus Money Pit
2000 Disco 2 Td5 Manual - dead and gone
197? Range Rover - gone
1973 SWB SIII Diesel, 1968 SWB IIA Petrol, 195? SI Petrol - all gone
Outback Campers Sturt
http://jandmf.com
Will give the converter a workout tomorrow getting home.
Darwin
03 disco 2a td5
series 2a [gunnado]
series 3 [gunnado]
and the tinny
Darwin
03 disco 2a td5
series 2a [gunnado]
series 3 [gunnado]
and the tinny
Better to remove the console.There are 13? Rivets to drill out.
regards PhilipA
Mark F...
Vk3KW
http://jandmf.com
Darwin
03 disco 2a td5
series 2a [gunnado]
series 3 [gunnado]
and the tinny
So made it the 150 odd kms home this morning with the lights gone and everything working as it should.I had cleared the fault yesterday afternoon last thing,fired it up this morning and drove it home,think i will start with a fluid level check first incase but if there is no leaks it cant be low[perhaps] leaning towards the wires instead of the xyz switch at this stage as the last 30 kms with the fault was pretty rough corrugations so possibly shook the wires into the right place, If the wires that were shorting suddenly were not shorting would of the M&S lights etc gone out or only when the fault was cleared.
Darwin
03 disco 2a td5
series 2a [gunnado]
series 3 [gunnado]
and the tinny
