Results 1 to 10 of 26
Thread: 82° thermostat? who's doing this and has it worked out for the long run?
    shayne86 Guest
    So after a few weeks with the new 04 v8 and trying to get my head around the sheer amount of heat these motors generate. I've taken a plunge & ordered an 82° thermostat to try.
    Yes i know these threads exists but the majority of them are circa 2012.
    Ide like to hear from people who have done this and are still running this mod. Or even those who did it and went back to factory.
    What has peoples experiences been in the long term running the slightly cooler 82° thermostat?
    Ill be going for a beach run next r&r and ide be lying if i said i wasnt somewhat stressing big time about the temps and heat that comes off these motors. Even under normal town driving conditions, it blows my mind.
    I guess 9 years in a turbo diesel dual cab which could be thrashed up and down a beach for days without breaking a sweet might be somewhat to blame for my worries.
    Im keen to hear anyone's feedback on this.
    Cheers everyone 82° thermostat? who's doing this and has it worked out for the long run?
    Oct 2007
    Brisbane West
    Still running a low temp inline top hose thermostat mate. 4.6 V8 D2. Still works well but in Winter the heater isn't what it was 82° thermostat? who's doing this and has it worked out for the long run?
    Sep 2010
    The Hills.
    152.79 MB
    How much heat are you talking about? What makes you think it's any hotter than your TD dual cab? Do you have a proper temp gauge, or is it a perception thing? If you've only had the car a few weeks, have you had the cooling system checked?
    For example, my son's TD42 Patrol generates far greater underbonnet temps than my TD5 Disco.... or so it seems. An accurate temp reading might surprise you. Or, of course, you may be right and it is hot. if it is there is possibly something wrong with it.
    ​JayTee
    Nullus Anxietus
    Cancer is gender blind.
    2000 D2 TD5 Auto: Tins
    1994 D1 300TDi Manual: Dave
    1980 SIII Petrol Tray: Doris
    OKApotamus #74
    Nanocom, D2 TD5 only.
    shayne86 Guest
    Quote Originally Posted by Tins View Post
    Because i could touch the panels and bonnet on my dual cab without being burned. The ute also didn't take an hour to cool down afterwards. Yes i know you couldn't get any more of a polar opposite than a cast iron turbo diesel to an ally petrol v8. But just seems odd to me. No i haven't had a chance to get the cooling system inspected yet.
    I have an obd2 wireless scanner coming so i can get an accurate read on the temp before i do change anything.
    Will be flushing the coolant anyways this r&r.
    shayne86 Guest
    I might add that the car does have a mostly full service history and the temp gauge never goes above half and comes up to temp fairly quick. It is high milage though at 270,000kms.
    Sep 2010
    The Hills.
    152.79 MB
    Quote Originally Posted by shayne86 View Post
    It won't take you long to work out that the factory gauge is a hopeless liar and is not to be trusted. It is an idiot light at best. Fit a proper one ASAP.
    ​JayTee
    Nullus Anxietus
    OKApotamus #74
    shayne86 Guest
    Yeah i have read that a lot 82° thermostat? who's doing this and has it worked out for the long run?
    Apr 2016
    Country Vic.
    .... and the temp gauge never goes above half and comes up to temp fairly quick. ....
    This means zero!
    The OBDII scanner thing will show you actual temps.
    My V8('00 model) temp gauge really only shows anything above half way once coolant temp is in the 115°C (IIRC .. maybe more!) temp range.
    Mine had a huge cooling problem, which I thought I solved(but turned out to be a major block shattering issue).
    So my experience with seriously overheating V8's dash gauges OBDII dongles and freebie software was eye opening.
    My understanding of modern vehicles tho is that most coolant temp gauges work similarly .. they just show the 'unaware' that everything is fine, and once the problem has already happened, only then will the gauge alert this 'unwary' driver that there is a problem.
    My brother had the same issue in his '00 Patrol(petrol) where the gauge only showed the coolant getting hot, AFTER the steam was billowing out the bonnet.
    To date, only car I can recall that has an actual temperature gauge that shows actual temps ... in the dash cluster .. is the Peugeot 307 HDi.
    My dad has one, and he's forever complaining that it goes up and down, up and down, he seems to think that when it goes up, it's overheating!
    I go through this repetitive routine, pretty much, every week with him(he's old .. maybe suffering memory loss).
    I used to see actual temps in the brothers(now gone) Iveco Stralis too. Cruising .. would show whatever cool normal temp, hard up a long hill, it'd heat a bit(as you'd expect) .. and coolant temps would rise .. gauge would show you this, viscous fan would start to roar.
    But just to reassure you .. your "never goes above half" gauge means coolant temp could be between about 60(-ish) and 115(-ish) °C
    Arthur.
    '03 D2 Td5 Auto
    '03 D2a Td5 Auto
    Oct 2007
    Brisbane West
    The D2 V8 runs too hot. The cooler thermostat is kinder to the block. Cheers
    shayne86 Guest
    AK83, yeah i had an obd2 scanner and the torque app in my Colorado. Thing was amazing! I had a custom 9 inch display with coolant temp, boost, engine load, egr, intake temp, manifold temp, fuel rail pressure, fuel flow, fuel temp..... more gauges than you could poke a stick at.
    The coolant temp was interesting though. So the cars factory gauge would run on the first quarter mark for day to day running. This equated to about 81° on the obd2.
    A jump on the cars gauge from quarter to half was only a water temp increase of about 5-6°! I never saw anything over half way on the gauge or 87° on the obd2.
