Page 1 of 6 123 ... LastLast
Results 1 to 10 of 56
Thread: SLS.
    Back down the hill.
    SLS.
    Last week I noticed, as it was parked, the right rear suspension was low. A short drive and the rear suspension was far more compliant than usual. During the drive home, a few days later, the rear became low and harsh.
    I suspected a leaking RH bag or broken air line. Today was the first opportunity to investigate and the RH bagappears inflated (very solid to touch) but running on the bumpstop.
    This leads me to believe the issue is with the ride height valve. Is there a RHV for each side of the car?
    Sep 2010
    The Hills.
    152.79 MB
    Yes. 12 and 13 in the second pic.
    Screen Shot 2021-03-22 at 1.50.28 pm.jpgScreen Shot 2021-03-22 at 1.53.07 pm.png
    ​JayTee
    Nullus Anxietus
    Cancer is gender blind.
    2000 D2 TD5 Auto: Tins
    1994 D1 300TDi Manual: Dave
    1980 SIII Petrol Tray: Doris
    OKApotamus #74
    Nanocom, D2 TD5 only.
    Jul 2014
    west of Transylvania
    I doubt this has anything to do with an air valve, it's more likely the bag especially if it keeps the level while driving. As long as it's on the bump stop it's clear that there's not enough air in that bag. Better replace it before the compressor burns out as it works in excess to compensate for the leak
    Back down the hill.
    The bag appears to be holding air, albeit not at the right height. This occured just after a number of reasonably deep water crossings. Both bags are Contis, a couple of years old.
    Jul 2014
    Then maybe the height sensor but a valve is the last suspect IMO
    Back down the hill.
    Quote Originally Posted by sierrafery View Post
    That was going to be my first port of call.
    Back down the hill.
    These numbers relate to what?
    The compressor doesn't seem to be working. I can neither hear nor feel vibration from it with the ignition on.
    I have substituted a known, working relay to no avail, eliminating that as a cause.
    Check fuse, good.
    How do I check the compressor and ride height sensors?
    The RH side is lower than the L, but both are down.
    Jul 2014
    Those are values related to heights as nanocom calculates them.
    sensor value: This shows the current height value of the air suspension
    height sensor. A value of 1 is equal to approximately 1.4 mm between the wheel arch
    and ground.
    Go to Utility - Calibration, you can activate the compressor from there to raise each side, each start will work for about 1cm. Make sure all the doors are closed and do it with engine running then when all is even store heights... though check at lesst visually the height sensors first eventually disconnect the battery and give some contact spray in the plugs
    Back down the hill.
    I've done a visual on the sensors, there's no apparent physical issues.
    Back down the hill.
    and ground.
    I tried that with the Nanocom, the car didn't lift at all, despite four or five tries. Does this confirm that the compressor is kaput?
