Results 1 to 4 of 4
Thread: List of bolt sizes and thread types used on a Series 1 Engine
    Jan 2017
    Gentlemen,
    I came across this list of bolt sizes and thread types used on Series 1 engines on a UK Land Rover Forum.
    Series 1 Engine Bolts Sizes and Thread Types
    1/4"UNF for the rear cam gallery plate fixing bolts & thermostat housing bolts.
    5/16"UNF for the cam gallery side covers, timing case, sump & the small rocker bolts.
    3/8"UNF for the flywheel housing to block bolts.
    7/16"UNF for the oil filter bolts.
    1/2"UNF for the large head bolts & the front engine mounting bolts into the block.
    1/4"UNC for the small water pump bolts & the timing pointer studs in the flywheel housing.
    3/8"UNC for the stud holes in the flywheel housing.
    1/8"BSP for the banjo bolts in the rocker oil feed pipe.
    This looks like very useful information, but I wonder if there is a better or more extensive list around?
    regards
    Jeff
    JDNSW's Avatar
    JDNSW is online now RoverLord Silver Subscriber
    I suggest someone who has a Series one should check this information. I was under the impression that Unified threads only came with Series 2, and would have guessed these threads were Whitworth and BSF.
    Narre Warren South
    I guess you'd only need a list of bolts if you haven't got the bolt that was removed or you're ordering new bolts without checking what's fitted ?
    Like John, I'd have thought most were BSF & Whitworth on the Series I. UNC & Whitworth are the same pitch 1/4" to 1/2" but different thread angles, whoever posted the list may have 'guessed' UNC.
    Had a look in the parts manual and size/length is given but not the thread type.
    You'd need to find someone with a lot of time on their hands to produce a list. Someone in the UK supplies complete nut & bolt kits but it's unlikely they list what goes where.
    Land Rover Body Fastener Kits, Spares, Land Rover Parts
    Colin
    '65 Series IIa Dormobile
    '70 SIIa GS
    '76 SIII 88" (Isuzu C240)
    '81 SIII FFR
    '95 Defender Tanami
    Motorcycles :-
    Jul 2009
    S.E.Qld
    Quote Originally Posted by jedwards View Post
    Gentlemen,
    regards
    Jeff
    Useful information ? It's rubbish. Check your S1 parts catalogue All the threads are BSF unless otherwise stated.
    .W.
