Thread: can the AMK compressor be serviced?
    Jun 2020
    So like literally everyone else on this forum at the moment I'm starting to get a suspension fault 'pressure does not decrease when venting gallery'. At the moment turning the car off and on again and the fault goes away and I can change heights but I imagine it will slowly become more severe. So I decided to take off the APT compressor guard and the compressor housing to check what type I have. Sadly it's the AMK, not the much raved about Hitachi.
    Can it be serviced? or at the very least is the desiccant canister the same and I can service/replace it?
    As an aside, the housing was solid full of dirt and sand. I have no idea how so much got into it as there's very little in the way of openings!
    St Helena,Melbourne
    1.13 MB
    Not as serviceable as a Hitachi but there are drier service kits available.
    2004 Jayco Freedom tin tent
    1998 Triumph Daytona T595
    1974 VW Kombi bus
    1958 Holden FC special sedan
    geoffmc is offline Fossicker Silver Subscriber
    Jan 2012
    Hi,
    I had the same code and replaced the compressor (AMK) and it was not the issue. I repaced each of the valve blocks independantly and the last valve block was the culprit. The centre unit behind the compressor.
    FYI, i have my original CMK unit, that has had a sevice kit through it(dessicant, O rings, filters) and was replaced at 66k. Its in perfect condition if you would like to know more.
    Geoff
    Quote Originally Posted by Macadamia View Post
    D4 TDV6 MY13 White - GONE
    Jun 2018
    Tamworth
    I just ordered a replacement centre block as I've replaced the front and rear (they were sinking.) Now I'm getting a compressor error after a service - hopefully that'll do it
    Jun 2020
    essentially I need to know if the drier/desiccant canister is the same between the two compressors so I can use for example the drier service kit from X8R. I did send them an email but they weren't sure.
    Jul 2020
    Urila
    looks different according to this http://4x4airseals.com/product-categ...er/discovery34
    St Helena,Melbourne
    1.13 MB
    Between amk and Hitachi ?, no completely different. No parts interchange.
    1974 VW Kombi bus
