Thread: Restricted Performance with no fault codes
    Mar 2010
    Karratha WA
    Looking for some advice, started getting the restricted performance message whilst driving the other day no extreme loads just city traffic.
    Plugged in the Gap iid tool no faults showing
    Read some posts so took off the engine cover had someone load up the engine no leaks or sparky that I can see.
    Tried a reset by disconnecting the battery fault cleared, as it does turning the car off for 1/2 hr however appears again within a couple of minutes doing less than 60 with no load. Still no faults registering on the Gap tool
    If there was a fault registered on the Gap tool at least I could pinpoint the issue
    Thanks in advance
    Mar 2016
    Did you enable ‘pending’ faults in the GAP application? If not, that’s why you’re not seeing them. You enable it within the settings area of the faults area if I recall correctly
    2007 Audi RS4 (B7)
    josh.huber Guest
    Yep that's it. My manifolds took ages before they came up on gap.
    350RRC's Avatar
    350RRC is offline ForumSage Silver Subscriber
    Cracked inlet manifolds almost seems to be a badge of honour on this forum.
    DL
    Mar 2010
    Karratha WA
    Discojeffster
    I will have a look this re pending codes.
    There were some fault codes that come up, however none I felt were related to restricted performance
