Results 1 to 10 of 30
Thread: Removing oil from driveway?
    Bracken Ridge, Qld
    So, I have a aggregate concrete driveway and its been liberally dosed with diff oil over a few months.
    I've tried degreaser (2 x spray tins), detergent and pressure washer but its still there.
    Has anyone got suggestions as to the best way to address?
    gone
    1993 Defender 110 ute "Doris"
    1996 Discovery 1
    current
    Jun 2008
    Drouin East, Vic
    I've never tried it but I've heard that 'liquid magnet' works. My dad used to swear by it.
    Nov 2008
    Mostly over there
    22.04 MB
    Watching with interest. Same problem but also the black engine oil and used oil from gearbox drippings and a mix of new from servicing 110 on the driveway. I leave a sheet of plywood under the truck to catch as much oil dripping as I can but I turn the truck 90 deg to get to the park and sometimes when running over the ply it twists and ends up elsewhere under the truck and oil stains happen...
    I see a newish product (new to me anyway) on the market from CRC called Oil Eater. CRC Oil Eater - Remove Oil Stains From Concrete - CRC NZ
    Going to give that a go so will report back.
    There are lots of Youtube videos on this with mixed results - the most effective does seem to be dishwashing liquid that is left in for quite a while before removing.
    I have found plain sunlight and 12 months time seems to work the best - the sunlight encourages the oil eating bacteria and they do their work but takes a long time.
    Bracken Ridge, Qld
    I should add I need a shorter term "impatient missus" solution
    gone
    1996 Discovery 1
    current
    Feb 2013
    Wamuran, Qld
    Good soaking with petrol, then throw a lit match at it.
    Ron
    2013 D4 SDV6 SE
    Aug 2010
    Sunbury, VIC
    When you own Land Rovers it’s just easier to live with the oil stains or park it on the grass. Removing oil from driveway?Removing oil from driveway?
    Feb 2010
    Quote Originally Posted by VladTepes View Post
    The concrete sealer I used is Ausseal Curite sealer. The guy doing my aggregate concrete driveway which is a used it. My 40 year old garage floor concrete got it after using Xylene and a stiff brush. It looks like new now.
    Suspect the acid might do the trick for you. adding the Curite or similar may allow you to just hose it off next time.
    Quote Originally Posted by NavyDiver View Post
    I use something very similar and it's fine.......... know its limitations though.
    DON'T spill acetone or xylene on it.
    DL
    Sep 2019
    NSW
    ...time is all you need. Oil stains from Landies marking their territory just become part of the patina of the driveway
