Thread: D4 Engine Idle Speed
    PK778 Guest
    Good afternoon all,
    Forgive me if this has already been covered but I am a new member just venturing into Green Oval ownership.
    I have a 2012 2.7 TDV6 with approx 230K Km on the clock. The engine idles at around 900 rpm indicated on the tacho, even when warmed up. This sounds a bit high to me but the place I bought her from reckons that's about normal. Quick Google indicates many potential areas of concern, many of which appear to indicate impending financial ruin.
    Does anyone have any advice on this, such as what idle speed would the car normally sit at and any possible easy remedies etc?
    Many thanks.
    Mine sits at about that - think you are worrying about nothing.
    Jul 2012
    Perth- South of the River
    Welcome to the club and forum.
    That sounds about right to me also. If you want, I'll check tomorrow and post the exact RPM.
    Gone 05 D3 ARB Front Kaymar Rear Winch E-Diff LRA Tank Dual Battery
    Current 2015 SDV6 SE. Tow Pro Mitch Hitch Llams C/motives 70ltr w/tank 2 x comp Traxide BMS-2 x Aux 150w Solar Uniden Engel ARB drawer F/Runner rack Light bar
    I went out just after my post - my tach shows about 850 at idle when warm - its a bit cold here tonight so cold was a bit over the place but from about 800 to 900rpm on start - that was after two glow plug cycles before starting.
    Sep 2014
    Baldivis WA
    Quote Originally Posted by PK778 View Post
    Good afternoon all,
    Many thanks.
    Sounds about right, but my basis is the 3.0 l. Mine idles around 750-800rpm when warm, a bit more when cold. Nothing to worry about, idle should be even and not hunt around, and also there should be no or minimal rattles and clicks etc. Check MAF and MAP sensors, easy to clean with some spray cleaner you can get from most autoparts stores.
    Jul 2012
    Good afternoon all,
    Many thanks.
    OK, So had a look with my Gap IIDTool. Cool start- Idle RP: 736. On the tacho the needle sits just below the 800 rpm mark.
    NB:
    1. 200 rpm increments not to be confused with 100 rpm increments .
    2. This is the 3.0 ltr.
    Feb 2019
    Bunbury WA
    Cool
    Quote Originally Posted by Dagilmo View Post
    NB:
    My 3.0 sits on the same as above with GAP tool also.
    Sep 2014
    Baldivis WA
    Same, measured with Rovacom VCIQ.
    PK778 Guest
    D4 Idle Speed
    Thanks to everyone who has taken the time and trouble to respond.
    Having read the replies I have kept a close eye on the car and all is well.
    Item 1 below is the killer, looks like my eyes need recalibrating to read a tacho correctly! She idles around 750-800.
    NB:
    Dec 2014
    Townsville
    My 2015 D4 TDV6 idles at 800 rpm warm.
