Results 1 to 10 of 13
Thread: Rear step? Easy to add? Pros and Cons
    May 2015
    Williamstown, Victoria
    I am thinking of putting a rear step. to make it easier to get up on to the roof rack. Do all cars have the mounting holes? Easy enough to fit? Pros and COns?
    TIA
    Build date 11th Oct 2003
    LROCV #1410
    Oct 2011
    Fremantle WA
    Quote Originally Posted by Bohica View Post
    TIA
    I bought on here and put the 7 seater rear step on my D2a and it was one of the best add-ons ever
    May 2015
    Quote Originally Posted by gavinwibrow View Post
    Easy enough to do? Holes in the right place?
    LROCV #1410
    Feb 2020
    Perth. Western Australia
    Here is some pics. No detailed instructions just like Ikea assembly guides.
    May help.
    some drilling may be needed but is simple enough.
    Jan 2011
    Gippsland
    Quote Originally Posted by Ronski View Post
    May help.
    I have the rear steel bar and plan to bolt on a stirrup made from 100x100mm square tube offcut - when I get around to finding a bit...
    LROCV member #131
    1999 build D2 TD5 Auto, Mantec snorkel, 2" LRA spring lift, ARB on board air, Ashcroft ATB, CMM air ram CDL shifter, swag & gold pans ....
    Oct 2011
    Fremantle WA
    Direct bolt in on my wee beastie. Wasn't affected by the steel rear bar.
    May 2015
    Thanks, I've ordered it and the rear door ladder. Good news about the rear stel bar as well!
    LROCV #1410
    Jan 2021
    Yes
    I use this almost everyday. Well worth doing!
    Jan 2011
    Gippsland
    I thought about selling a kidney to fund one - not cheap are they Rear step? Easy to add? Pros and ConsRear step? Easy to add? Pros and Cons
    LROCV member #131
    Jul 2017
    Victoria
    What the rear bar?
    Quote Originally Posted by onebob View Post
    03 D2a Manual Td5 Modified, Ashcroft lockers F&R, Ashcroft R380,Atb lt230, Ashcroft Rear axles, AS manual IC, AS exhuast manifold, AS Coolant bottle, 3inch exhaust, alive GTB550 VGT, billies 7100s, 3inch lift, 4inch staino snorkel, 35s beadlocked
