Page 1 of 10 123 ... LastLast
Results 1 to 10 of 99
Thread: All wheel drive vs 4 wheel drive vs ?
    Jul 2003
    So the Land Rover specs contain the following small print:
    "1 Permanent All-Wheel Drive is standard on Land Rover Defender except for those fitted with new D200, D250 and D300 6-cylinder Diesel engines"
    Can anyone here explain what that means and why it applies only to the diesel-engined variety?
    Land Rover doesn't give any explanation as far as I can tell.
    Mahn England
    Ex 300Tdi Disco:
    Jun 2008
    The new Gold Coast, after ocean rises,Queensland
    you have to get out and engage the locking hubs....simple
    this gives you the opportunity to inspect the terrain that the all round cameras and sensors have already assessed.
    Sep 2011
    Whitsundays and sometimes Sydney
    Quote Originally Posted by one_iota View Post
    The D MHEV programmes can determine and disconnect the front wheels from the drive train if not required as far as i can remember,
    uses some clutch pack, idea is to save you a minuscule amount of Diesel when on tarmac..and no doubt ensures Gerry Mc can
    state he has green credentials
    edited: Diagram added
    Sep 2011
    "Intelligent all wheel drive" is the phrase
    Brisbane,some of the time.
    More complications with very little up side.
    Jun 2017
    Yep. This is one of the reasons why when I suddenly found myself with the opportunity to change vehicles late last year I bought a 20MY vehicle in the wrong colour and with an unwanted sunroof from dealer stock rather than ordering a new build. The new driveline on the 6-cyl diesels is apparently a tiny smidge more fuel efficient but really seems like a step backwards in terms of driving four wheels with optimum traction.
    Where the electronic centre diff has for a couple decades given us permanent AWD with automatic centre diff locking as needed, the new system is basically an automatic clutch version of the old 2H/4H and locking hubs arrangement. The only reason for doing it is to reduce spinning mass and friction losses in situations where RWD will suffice. Doesn't seem right for a Defender, especially a diesel one.
    Brisbane, Queensland
    Ok does that mean all current model
    Defender diesels are now intelligent (part time) FWD, and only the petrols non hybrid are full time FWD?
    L322 tdv8 poverty pack - wow
    Track Trailer ARN 200-117
    REMLR # 137
    Jul 2003
    Quote Originally Posted by rar110 View Post
    That is how I read it.
    It begs the question "why only diesels?"
    If there are economies and emission reductions to be had albeit marginal why not also with the petrol engine?
    Mahn England
    Ex 300Tdi Disco:
    Jun 2017
    Depends what you mean by "FWD".
    If your "F" means "Front", then no. The transfer case doesn't have a differential component any more, and the rear drive shaft is a permanent connection from the TC to the rear diff. The rear wheels are always driven. The centre clutch controls whether any drive is also given to the front, but remember there's no diff so it's a 1:1 ratio just like old-school 4WD mechanisms.
    If your "F" means "Four" then yes.
    Jul 2003
    Quote Originally Posted by zilch View Post
    I think what we are witnessing are the dying throws of the diesel engine given the emission control regulations being introduced particularly in Europe. Canada and the USA don't import the diesel-engined versions.
    These are marginal gains from major engineering efforts. We are working beyond the Pareto principle.
    Mahn England
    Ex 300Tdi Disco:
