Results 1 to 2 of 2
Thread: Connecting light bar to D4 with Bi Xenon
    May 2020
    Geelong
    Hey guys, Installing a new Stedi light bar to my 2015 D4 with Bi Xenon. Wiring harness piece for the high beam trigger has two wires (Black + Red). From what I can see on previous posts I need to tap into the Blue/Grey wire for the trigger (Which I assume I'd use the red wire). I assume the black wire on the harness is for the earth? Do I need to get this earth from the headlights? It's a plug + play kit but obviously this is not possible with the Xenons so just working out what I tap into. Thanks guys, Cheers Haydn
    NSW SW Slopes
    The earth pickup can be from any earth stud on the body, just don't connect it to the battery terminal. All the headlight connection earths go to a body stud.
