Results 1 to 10 of 30
Thread: Coolant Hoses
    May 2009
    Tatura, Vic
    Coolant Hoses
    Whilst my engine is out I want to change my coolant hoses, as they all the originals since new.
    What are you using. Looking at genuine I would need to sell a kidney to fund this.
    Are after market ok? Best place to buy?
    Dave.
    I was asked " Is it ignorance or apathy?" I replied "I don't know and I don't care."
    1983 RR gone (wish I kept it)
    1996 TDI ES.
    2003 TD5 HSE
    1987 Isuzu County
    NSW far north coast
    I use genuine except for the top hose (good brand silicone) as the new genuine hoses weep back through the plies, the vulcanising on the tees isn't great.
    Oh, and a silicone blank on the oil cooler outlet.
    Hoses are one spot in particular i won't scrimp and take a risk
    May 2021
    Mackay
    I purchased my hoses on eBay which seems to work out cheaper than buying from online retailers when postage is required. Cost under $200 for "most" of the hoses on two orders (still haven't got my head around the complexities of the d2 cooling circuit yet, lol). Hoses were described as EOM, and they do look much like the originals, but made in Pakistan. Been on for a only a couple of weeks but no leaks or any dramas with installation. Time will tell how long they will hold up, I guess.
    Jan 2011
    Gippsland
    Quote Originally Posted by d2dave View Post
    Collectively over a period of time I have purchased all new “genuine” hoses. Latterly adding an OEM thermostat, a water pump and new rad to the pile of stuff to refit. The most expensive hose is the top hose - don’t go cheap with this one. Roverlord is where I got my hoses.
    LROCV member #131
    1999 build D2 TD5 Auto, Mantec snorkel, 2" LRA spring lift, ARB on board air, Ashcroft ATB, CMM air ram CDL shifter, swag & gold pans ....
    Does Mackay still make hoses in Australia? They made the hoses for the Perentie and a number of Aussie built cars.
    May 2009
    Tatura, Vic
    Quote Originally Posted by rick130 View Post
    I'm guessing this is because of turbo heat, yes?
    Where can I get one of these? I looked on ebay and could only find them in China.
    Dave.
    1996 TDI ES.
    2003 TD5 HSE
    1987 Isuzu County
    May 2009
    Tatura, Vic
    Quote Originally Posted by onebob View Post
    I looked there and he had no hoses, only thermostat.
    Dave.
    1996 TDI ES.
    2003 TD5 HSE
    1987 Isuzu County
    Apr 2012
    Whyalla, SA
    Put simply - pattern parts are usually made from Generation one OE.
    Over time the OE get updated (eg TD5 top hose to stop it rubbing) but the Pattern Parts do not.
    Tread carefully Coolant Hoses
    Or go full Silicone Coolant Hoses$$
    May 2009
    Tatura, Vic
    Are silicon hosed that good. I had always thought they were, but some recent research has suggested otherwise.
    Dave.
    1996 TDI ES.
    2003 TD5 HSE
    1987 Isuzu County
    Jan 2011
    Gippsland
    Coolant Hoses
    I never look at his online shop - I make a parts request via email. Seldom can he not supply, like when I asked for a Starter Motor rebuild kit, or a Lt230 Transfer Case rebuild kit. But in the case of the more “commonly” sought after items like filters, thermostats, water pumps and hoses… never a problem Coolant Hoses
    LROCV member #131
