Todays odd D2 behaviour.
So today I went unlock my D2a using the key fob and the car did not unlock. I did notice the interior light did come on though. Tried a second key, same issue.
I then unlocked my car using the physical key which set off the car alarm, pressing the button on the key fob stopped the alarm.
I then shut the door and the key fob would not lock the door.
So I turned the key to the second position and the car gave three dongs, not the normal three dings, but dongs. Never heard them before. And where the P/D/R would normally be displayed, it looked like all three were on at once, and flashing. Photo attached.
I then started the car with no issue. Ran the car though the different transmission position and the display didn't change. Checked the nanocom and the position switches all changed correctly. Also no errors were posted on any computer.
So I did a lap of the block and the car drove fine except the blinkers/hazards didnt work. Pulled up and turned it all off. Turned it back on same issues.
Got out of the car, and it locked with the key fob. Unlocked with the key fob. And no dongs, transmission position reports correct, and the blinkers work.
Now it has been raining, so that may have something to do with it. The top of my windscreen used to leak but it was fix a while ago. But I cant guarantee there isn't some water on the back of the fuse box which may caused a computer to have a brain fart.
I thought maybe a low voltage battery but the car started fast and hard first go and I didnt get any computer errors which usually come with such a situation.
Anyone have an idea what may have happened?
2003 D2a TD5 Auto
1960 Series 2 Petrol
